[Qgis-developer] How to change splash screen in QGIS 1.8 and where is the location of that splash acreen in qgis 1.8 ?
kranthi kumar kranthikumar6789 at gmail.com
Sun Jul 22 22:17:45 PDT 2012
can you please tell how to use -nosplash screen in window ?
On 21 July 2012 15:04, kranthi kumar <kranthikumar6789 at gmail.com> wrote:
> ---------- Forwarded message ----------
> From: kranthi kumar <kranthikumar6789 at gmail.com>
> Date: 20 July 2012 18:16
> Subject: Re: [Qgis-developer] How to change splash screen in QGIS 1.8
> To: Marco Bernasocchi <marco at bernawebdesign.ch>
> ok, i will do with your suggestions :)
> On 20 July 2012 18:15, Marco Bernasocchi <marco at bernawebdesign.ch> wrote:
>> Hi,
>> On 07/20/2012 02:35 PM, Nathan Woodrow wrote:
>>> You can stop it using --nosplash but you can't change it.
>>> - Nathan
>>> On Fri, Jul 20, 2012 at 10:31 PM, kranthi kumar
>>>> ok thank you..
>>>> is there any option to stop the splash screen and through command
>>>> prompt and allocating the new image as splash screen ?
>>>> On 20 July 2012 17:59, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>> It doesn't exist on the file system after QGIS is installed, it is
>>>>> compiled into the application.
>>>>> - Nathan
>>>>> On Fri, Jul 20, 2012 at 10:25 PM, kranthi kumar
>>>>>> Thank you for giving reply....
>>>>>> actually i am developing one new application,
>> So you probably build it yourself no? so change the splash before compiling.
>>>>>>   for that i need to
>>>>>> change the splash screen.
>>>>>> in qgis 1.7, splash screen is available in images/splash/splash.png....
>>>>>> but now i want to change the splash screen in qgis 1.8
>>>>>>   so please tell where is the exact location of splash screen in qgis
>>>>>> 1.8 after installed into the system
>>>>>> thanking you
>>>>>> On 20 July 2012 17:51, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>>>> The splash screen is complied into the resources of QGIS and currently
>>>>>>> can't be changed at runtime.  If you need to change it you must
>>>>>>> recompile QGIS.
>>>>>>> - Nathan
>>>>>>> On Fri, Jul 20, 2012 at 10:18 PM, kranthi kumar
>>>>>>>> please do let me know about my question as soon as possible
>> as well, it is nice to put the question in the text and not make super long
>> subjects.
>>>>>>>> Regards,
>>>>>>>> B Kranthi Kumar,
>>>>>>>> Project Engineer,
>>>>>>>> C-DAC (R & D)-Pune-411007.
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-developer mailing list
>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> Regards,
>>>>>> B Kranthi Kumar,
>>>>>> Project Engineer,
>>>> Regards,
>>>> B Kranthi Kumar,
>>>> Project Engineer,
>> Marco Bernasocchi
>> http://opengis.ch
> Regards,
> B Kranthi Kumar,
> Project Engineer,
> Regards,
> B Kranthi Kumar,
> Project Engineer,
Regards,
B Kranthi Kumar,
Project Engineer,
