[Qgis-developer] How to change splash screen in QGIS 1.8 and where is the location of that splash acreen in qgis 1.8 ?
kranthi kumar
kranthikumar6789 at gmail.com
Mon Jul 23 01:14:12 PDT 2012
can any one tell me how to stop spash screen using --nosplash in
command prompt ?
please answer my question as soon as possible
On 23 July 2012 10:47, kranthi kumar <kranthikumar6789 at gmail.com> wrote:
> can you please tell how to use -nosplash screen in window ?
> On 21 July 2012 15:04, kranthi kumar <kranthikumar6789 at gmail.com> wrote:
>> ---------- Forwarded message ----------
>> From: kranthi kumar <kranthikumar6789 at gmail.com>
>> Date: 20 July 2012 18:16
>> Subject: Re: [Qgis-developer] How to change splash screen in QGIS 1.8
>> To: Marco Bernasocchi <marco at bernawebdesign.ch>
>> ok, i will do with your suggestions :)
>> On 20 July 2012 18:15, Marco Bernasocchi <marco at bernawebdesign.ch> wrote:
>>> Hi,
>>> On 07/20/2012 02:35 PM, Nathan Woodrow wrote:
>>>> You can stop it using --nosplash but you can't change it.
>>>> - Nathan
>>>> On Fri, Jul 20, 2012 at 10:31 PM, kranthi kumar
>>>>> ok thank you..
>>>>> is there any option to stop the splash screen and through command
>>>>> prompt and allocating the new image as splash screen ?
>>>>> On 20 July 2012 17:59, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>>> It doesn't exist on the file system after QGIS is installed, it is
>>>>>> compiled into the application.
>>>>>> - Nathan
>>>>>> On Fri, Jul 20, 2012 at 10:25 PM, kranthi kumar
>>>>>>> Thank you for giving reply....
>>>>>>> actually i am developing one new application,
>>> So you probably build it yourself no? so change the splash before compiling.
>>>>>>> for that i need to
>>>>>>> change the splash screen.
>>>>>>> in qgis 1.7, splash screen is available in images/splash/splash.png....
>>>>>>> but now i want to change the splash screen in qgis 1.8
>>>>>>> so please tell where is the exact location of splash screen in qgis
>>>>>>> 1.8 after installed into the system
>>>>>>> thanking you
>>>>>>> On 20 July 2012 17:51, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>>>>> The splash screen is complied into the resources of QGIS and currently
>>>>>>>> can't be changed at runtime. If you need to change it you must
>>>>>>>> recompile QGIS.
>>>>>>>> - Nathan
>>>>>>>> On Fri, Jul 20, 2012 at 10:18 PM, kranthi kumar
>>>>>>>>> please do let me know about my question as soon as possible
>>> as well, it is nice to put the question in the text and not make super long
>>> subjects.
>>>>>>>>> Regards,
>>>>>>>>> B Kranthi Kumar,
>>>>>>>>> Project Engineer,
>>>>>>>>> C-DAC (R & D)-Pune-411007.
>>>>>>>>> _______________________________________________
>>>>>>>>> Qgis-developer mailing list
>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>> Regards,
>>>>>>> B Kranthi Kumar,
>>>>>>> Project Engineer,
>>>>> Regards,
>>>>> B Kranthi Kumar,
>>>>> Project Engineer,
>>> Marco Bernasocchi
>>> http://opengis.ch
>> Regards,
>> B Kranthi Kumar,
>> Project Engineer,
>> Regards,
>> B Kranthi Kumar,
>> Project Engineer,
> Regards,
> B Kranthi Kumar,
> Project Engineer,
Regards,
B Kranthi Kumar,
Project Engineer,
