[Qgis-developer] Announcing raster-pipes-2 branch for testing
Tim Sutton
lists at linfiniti.com
Tue Jul 24 13:19:47 PDT 2012
Hi
On Tue, Jul 24, 2012 at 8:44 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Tue, Jul 24, 2012 at 7:15 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> On Tue, Jul 24, 2012 at 4:53 PM, Marco Hugentobler
>> <marco.hugentobler at sourcepole.ch> wrote:
>>> Hi all
>>> I think it would be a good move to merge the raster-pipes-2 branch back to
>>> trunk. Ok, I know more instabilities, things to polish, etc. But in trunk,
>>> it receives more attention and people are more motivated to work on it.
>>> Any objections?
>> Tests should pass OK before merge, I think. Then +1.
> Fixed. Now +1.
+1 from me
Regards
Tim
> Radim
>> Do you want to merge everything as a single commit or all commits from
>> raster-pipes-2? I would prefer to squash my initial work on pipes
>> (87607187-2fdd82f4) into a single commit.
>> Radim
>>> Regards,
>>> Marco
>>> Am 20.07.2012 22:15, schrieb Tim Sutton:
>>>> Hi
>>>> On Fri, Jul 20, 2012 at 10:13 PM, Etienne Tourigny
>>>> <etourigny.dev at gmail.com> wrote:
>>>>> Ok this is a more general question then - which format(s) should
>>>>> raster export support?
>>>> It should support any GDAL raster driver that supports write and that
>>>> is useable with the active dataset.
>>>> I was referring to tif only in terms of the default profiles I mentioned.
>>>> Regards
>>>> Tim
>>>>> Etienne
>>>>> On Fri, Jul 20, 2012 at 5:11 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>>>>> Hi
>>>>>> On Fri, Jul 20, 2012 at 10:07 PM, Etienne Tourigny
>>>>>>>> One thing that would be really nice is to have
>>>>>>>> some default profiles:
>>>>>>>> - options for maximum read performance regardless of disk space
>>>>>>>> - options for minumum file size regardless of performance
>>>>>>>> - options for 'middle of the road' between the above two
>>>>>>> would you have these options for all file types? it could get a little
>>>>>>> complex, but worth the effort. For now I am implementing 1 default for
>>>>>>> each driver, which can be defined by the user.
>>>>>> I was thinking just for tiff as I think it is the most generically used.
>>>>>> Regards
>>>>>> Tim
>>>>>>> Etienne
>>>>>>>> Regards
>>>>>>>> Tim
>>>>>>>>>> I have granted you write access, please work directly in
>>>>>>>>>> raster-pipes-2.
>>>>>>>>> thanks
>>>>>>>>> Etienne
>>>>>>>>>> Radim
>>>>>>>>>>> Etienne
>>>>>>>>>>> On Thu, Jul 19, 2012 at 7:21 PM, Tim Sutton <lists at linfiniti.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Hi
>>>>>>>>>>>> On Fri, Jul 20, 2012 at 12:19 AM, Etienne Tourigny
>>>>>>>>>>>>> On Thu, Jul 19, 2012 at 4:09 PM, Marco Hugentobler
>>>>>>>>>>>>>> Hi Etienne
>>>>>>>>>>>>>> Thanks for the feedback, very much appreciated. I've fixed these
>>>>>>>>>>>>>> issues in
>>>>>>>>>>>>>> raster-pipes-2 branch now.
>>>>>>>>>>>>>> There are still a few things missing in raster saving:
>>>>>>>>>>>>>> - write colortable to output dataset
>>>>>>>>>>>>>> - format specific options (e.g. compression)
>>>>>>>>>>>>>> - dynamic populating of the format combo box (currently
>>>>>>>>>>>>>> hardcoded to
>>>>>>>>>>>>>> geotiff)
>>>>>>>>>>>>>> - progress indication for tile based saving and possibility to
>>>>>>>>>>>>>> cancel
>>>>>>>>>>>>> It just occurred to me that it would be a great thing to
>>>>>>>>>>>>> implement
>>>>>>>>>>>>> this as a widget+class in QgisGui, so that it could be used
>>>>>>>>>>>>> elsewhere
>>>>>>>>>>>>> (e.g. gdaltools, sextante).
>>>>>>>>>>>> You mean as a reusable widget like the crs selector? Yes that
>>>>>>>>>>>> would be great!
>>>>>>>>>>>> Regards
>>>>>>>>>>>> Tim
>>>>>>>>>>>>> Any way I can help?
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Marco
>>>>>>>>>>>>>> On 18.07.2012 21:12, Etienne Tourigny wrote:
>>>>>>>>>>>>>>> Noticed a few issues with the save dialog
>>>>>>>>>>>>>>> 1) "format" drop-down is empty
>>>>>>>>>>>>>>> 2) cannot select a new file
>>>>>>>>>>>>>>> 3) segfault when saving to an existing file
>>>>>>>>>>>>>>> 4) It would be nice to have that action in the legend
>>>>>>>>>>>>>>> contextual menu,
>>>>>>>>>>>>>>> like for vector layers.
>>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>>> Etienne
>>>>>>>>>>>>>>> On Wed, Jul 18, 2012 at 3:59 PM, Etienne Tourigny
>>>>>>>>>>>>>>>> That's great news!
>>>>>>>>>>>>>>>> Concerning raster saving - will there be a mechanism for
>>>>>>>>>>>>>>>> compressing
>>>>>>>>>>>>>>>> files?
>>>>>>>>>>>>>>>> It would be great if default compression schemes could be
>>>>>>>>>>>>>>>> chosen for
>>>>>>>>>>>>>>>> different file types, and an option at save time - sort of
>>>>>>>>>>>>>>>> like image
>>>>>>>>>>>>>>>> editors.
>>>>>>>>>>>>>>>> I had trouble building it with external spatialite, could only
>>>>>>>>>>>>>>>> get it
>>>>>>>>>>>>>>>> to compile with cmake -DWITH_INTERNAL_SPATIALITE=TRUE - does
>>>>>>>>>>>>>>>> this
>>>>>>>>>>>>>>>> require a special version of spatialite?
>>>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>>>> Etienne
>>>>>>>>>>>>>>>> On Wed, Jul 18, 2012 at 12:13 PM, Marco Hugentobler
>>>>>>>>>>>>>>>>> Hi devs
>>>>>>>>>>>>>>>>> I'd like to announce the branch 'raster-pipes-2' in Radims
>>>>>>>>>>>>>>>>> repository
>>>>>>>>>>>>>>>>> https://github.com/blazek/Quantum-GIS for testing.
>>>>>>>>>>>>>>>>> Radim did a great job in refactoring the process of reading /
>>>>>>>>>>>>>>>>> resampling
>>>>>>>>>>>>>>>>> reprojecting / displaying / modifying raster layers. Every
>>>>>>>>>>>>>>>>> step is now a
>>>>>>>>>>>>>>>>> subclass of QgsRasterInterface, with the advantage that
>>>>>>>>>>>>>>>>> several steps
>>>>>>>>>>>>>>>>> can be
>>>>>>>>>>>>>>>>> chained in a QgsRasterPipe. Like that, the raster
>>>>>>>>>>>>>>>>> functionality is
>>>>>>>>>>>>>>>>> nicely
>>>>>>>>>>>>>>>>> separated into different classes and it is easy to add/remove
>>>>>>>>>>>>>>>>> elements
>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>> the pipe. The iteration over the raster parts is controlled
>>>>>>>>>>>>>>>>> by
>>>>>>>>>>>>>>>>> QgsRasterIterator (because for high-resolution prints or
>>>>>>>>>>>>>>>>> analysis on
>>>>>>>>>>>>>>>>> large
>>>>>>>>>>>>>>>>> datasets, it is impossible to keep everything in memory at
>>>>>>>>>>>>>>>>> once).
>>>>>>>>>>>>>>>>> Please report any issue you find in the branch to the
>>>>>>>>>>>>>>>>> developer mailing
>>>>>>>>>>>>>>>>> list.
>>>>>>>>>>>>>>>>> Besides the changes in code architecture, there is also a new
>>>>>>>>>>>>>>>>> feature in
>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>> raster-pipes-2 branch. It is now possible to write through
>>>>>>>>>>>>>>>>> QgsRasterDataProvider (currently only supported by the gdal
>>>>>>>>>>>>>>>>> provider).
>>>>>>>>>>>>>>>>> There
>>>>>>>>>>>>>>>>> is a 'save as...' function also for rasters now (though it is
>>>>>>>>>>>>>>>>> not 100%
>>>>>>>>>>>>>>>>> complete at the moment). There is the option to save a raster
>>>>>>>>>>>>>>>>> in one
>>>>>>>>>>>>>>>>> file or
>>>>>>>>>>>>>>>>> in tiles (the tiles are then saved in one directory and vrt /
>>>>>>>>>>>>>>>>> pyramides
>>>>>>>>>>>>>>>>> are
>>>>>>>>>>>>>>>>> automatically created. Very usefull for saving the contents
>>>>>>>>>>>>>>>>> of a WMS
>>>>>>>>>>>>>>>>> layer).
>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>> Marco
>>>>>>>>>>>>>>>>> Dr. Marco Hugentobler
>>>>>>>>>>>>>>>>> Sourcepole - Linux & Open Source Solutions
>>>>>>>>>>>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>>>>>>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>>>>>>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>> Qgis-developer mailing list
>>>>>>>>>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>>>>>>>>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>>>>>>>>>>>> Tim Sutton - QGIS Project Steering Committee Member (Release
>>>>>>>>>>>> Manager)
>>>>>>>>>>>> Please do not email me off-list with technical
>>>>>>>>>>>> support questions. Using the lists will gain
>>>>>>>>>>>> more exposure for your issues and the knowledge
>>>>>>>>>>>> surrounding your issue will be shared with all.
>>>>>>>>>>>> Visit http://linfiniti.com to find out about:
>>>>>>>>>>>> * QGIS programming and support services
>>>>>>>>>>>> * Mapserver and PostGIS based hosting plans
>>>>>>>>>>>> * FOSS Consulting Services
>>>>>>>>>>>> Skype: timlinux
>>>>>>>>>>>> Irc: timlinux on #qgis at freenode.net
>>>>>>>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>>>>>>>> Skype: timlinux
>>>>>> Skype: timlinux
Skype: timlinux
