[Qgis-developer] Announcing raster-pipes-2 branch for testing
Etienne Tourigny etourigny.dev at gmail.com
Wed Jul 25 05:00:12 PDT 2012
+1 for me also
It would be nice to discuss how the file save as dialog should be
organised, and how much of it could be reusable.
I think that a first candidate for using the file save as dialog
components would be gdaltools - see the modified merge tool.
Some elements might not be necessary in all use cases.  For example,
we could have an overviews section (line in the gdaltools overviews
tool), but it would not be necessary in other dialogs.
In the case of the full-blown "save as" dialog, all components could
be present, but with a ui to hide/display them (with something like a
toolbox, tabs, collapsible comboboxes).
What I have done for the format options is make is a standalone
widget, and it is included in the file save as dialog and gdal
options, as well as in the gdaltools dialogs (overviews only for
illustration). Would we want that for every component, or perhaps have
a single widget with optional sections that can be displayed according
to context?.
cheers
Etienne
On Tue, Jul 24, 2012 at 3:44 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Tue, Jul 24, 2012 at 7:15 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> On Tue, Jul 24, 2012 at 4:53 PM, Marco Hugentobler
>> <marco.hugentobler at sourcepole.ch> wrote:
>>> Hi all
>>> I think it would be a good move to merge the raster-pipes-2 branch back to
>>> trunk. Ok, I know more instabilities, things to polish, etc. But in trunk,
>>> it receives more attention and people are more motivated to work on it.
>>> Any objections?
>> Tests should pass OK before merge, I think. Then +1.
> Fixed. Now +1.
> Radim
>> Do you want to merge everything as a single commit or all commits from
>> raster-pipes-2? I would prefer to squash my initial work on pipes
>> (87607187-2fdd82f4) into a single commit.
>> Radim
>>> Regards,
>>> Marco
>>> Am 20.07.2012 22:15, schrieb Tim Sutton:
>>>> Hi
>>>> On Fri, Jul 20, 2012 at 10:13 PM, Etienne Tourigny
>>>> <etourigny.dev at gmail.com> wrote:
>>>>> Ok this is a more general question then - which format(s) should
>>>>> raster export support?
>>>> It should support any GDAL raster driver that supports write and that
>>>> is useable with the active dataset.
>>>> I was referring to tif only in terms of the default profiles I mentioned.
>>>> Regards
>>>> Tim
>>>>> Etienne
>>>>> On Fri, Jul 20, 2012 at 5:11 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>>>>> Hi
>>>>>> On Fri, Jul 20, 2012 at 10:07 PM, Etienne Tourigny
>>>>>>>> One thing that would be really nice is to have
>>>>>>>> some default profiles:
>>>>>>>> - options for maximum read performance regardless of disk space
>>>>>>>> - options for minumum file size regardless of performance
>>>>>>>> - options for 'middle of the road' between the above two
>>>>>>> would you have these options for all file types? it could get a little
>>>>>>> complex, but worth the effort. For now I am implementing 1 default for
>>>>>>> each driver, which can be defined by the user.
>>>>>> I was thinking just for tiff as I think it is the most generically used.
>>>>>> Regards
>>>>>> Tim
>>>>>>> Etienne
>>>>>>>> Regards
>>>>>>>> Tim
>>>>>>>>>> I have granted you write access, please work directly in
>>>>>>>>>> raster-pipes-2.
>>>>>>>>> thanks
>>>>>>>>> Etienne
>>>>>>>>>> Radim
>>>>>>>>>>> Etienne
>>>>>>>>>>> On Thu, Jul 19, 2012 at 7:21 PM, Tim Sutton <lists at linfiniti.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Hi
>>>>>>>>>>>> On Fri, Jul 20, 2012 at 12:19 AM, Etienne Tourigny
>>>>>>>>>>>>> On Thu, Jul 19, 2012 at 4:09 PM, Marco Hugentobler
>>>>>>>>>>>>>> Hi Etienne
>>>>>>>>>>>>>> Thanks for the feedback, very much appreciated. I've fixed these
>>>>>>>>>>>>>> issues in
>>>>>>>>>>>>>> raster-pipes-2 branch now.
>>>>>>>>>>>>>> There are still a few things missing in raster saving:
>>>>>>>>>>>>>> - write colortable to output dataset
>>>>>>>>>>>>>> - format specific options (e.g. compression)
>>>>>>>>>>>>>> - dynamic populating of the format combo box (currently
>>>>>>>>>>>>>> hardcoded to
>>>>>>>>>>>>>> geotiff)
>>>>>>>>>>>>>> - progress indication for tile based saving and possibility to
>>>>>>>>>>>>>> cancel
>>>>>>>>>>>>> It just occurred to me that it would be a great thing to
>>>>>>>>>>>>> implement
>>>>>>>>>>>>> this as a widget+class in QgisGui, so that it could be used
>>>>>>>>>>>>> elsewhere
>>>>>>>>>>>>> (e.g. gdaltools, sextante).
>>>>>>>>>>>> You mean as a reusable widget like the crs selector? Yes that
>>>>>>>>>>>> would be great!
>>>>>>>>>>>> Regards
>>>>>>>>>>>> Tim
>>>>>>>>>>>>> Any way I can help?
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Marco
>>>>>>>>>>>>>> On 18.07.2012 21:12, Etienne Tourigny wrote:
>>>>>>>>>>>>>>> Noticed a few issues with the save dialog
>>>>>>>>>>>>>>>    1) "format" drop-down is empty
>>>>>>>>>>>>>>> 2) cannot select a new file
>>>>>>>>>>>>>>> 3) segfault when saving to an existing file
>>>>>>>>>>>>>>> 4) It would be nice to have that action in the legend
>>>>>>>>>>>>>>> contextual menu,
>>>>>>>>>>>>>>> like for vector layers.
>>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>>> Etienne
>>>>>>>>>>>>>>> On Wed, Jul 18, 2012 at 3:59 PM, Etienne Tourigny
>>>>>>>>>>>>>>>> That's great news!
>>>>>>>>>>>>>>>> Concerning raster saving - will there be a mechanism for
>>>>>>>>>>>>>>>> compressing
>>>>>>>>>>>>>>>> files?
>>>>>>>>>>>>>>>> It would be great if default compression schemes could be
>>>>>>>>>>>>>>>> chosen for
>>>>>>>>>>>>>>>> different file types, and an option at save time - sort of
>>>>>>>>>>>>>>>> like image
>>>>>>>>>>>>>>>> editors.
>>>>>>>>>>>>>>>> I had trouble building it with external spatialite, could only
>>>>>>>>>>>>>>>> get it
>>>>>>>>>>>>>>>> to compile with cmake -DWITH_INTERNAL_SPATIALITE=TRUE - does
>>>>>>>>>>>>>>>> this
>>>>>>>>>>>>>>>> require a special version of spatialite?
>>>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>>>> Etienne
>>>>>>>>>>>>>>>> On Wed, Jul 18, 2012 at 12:13 PM, Marco Hugentobler
>>>>>>>>>>>>>>>>> Hi devs
>>>>>>>>>>>>>>>>> I'd like to announce the branch 'raster-pipes-2' in Radims
>>>>>>>>>>>>>>>>> repository
>>>>>>>>>>>>>>>>> https://github.com/blazek/Quantum-GIS for testing.
>>>>>>>>>>>>>>>>> Radim did a great job in refactoring the process of reading /
>>>>>>>>>>>>>>>>> resampling
>>>>>>>>>>>>>>>>> reprojecting / displaying / modifying raster layers. Every
>>>>>>>>>>>>>>>>> step is now a
>>>>>>>>>>>>>>>>> subclass of QgsRasterInterface, with the advantage that
>>>>>>>>>>>>>>>>> several steps
>>>>>>>>>>>>>>>>> can be
>>>>>>>>>>>>>>>>> chained in a QgsRasterPipe. Like that, the raster
>>>>>>>>>>>>>>>>> functionality is
>>>>>>>>>>>>>>>>> nicely
>>>>>>>>>>>>>>>>> separated into different classes and it is easy to add/remove
>>>>>>>>>>>>>>>>> elements
>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>> the pipe. The iteration over the raster parts is controlled
>>>>>>>>>>>>>>>>> by
>>>>>>>>>>>>>>>>> QgsRasterIterator (because for high-resolution prints or
>>>>>>>>>>>>>>>>> analysis on
>>>>>>>>>>>>>>>>> large
>>>>>>>>>>>>>>>>> datasets, it is impossible to keep everything in memory at
>>>>>>>>>>>>>>>>> once).
>>>>>>>>>>>>>>>>> Please report any issue you find in the branch to the
>>>>>>>>>>>>>>>>> developer mailing
>>>>>>>>>>>>>>>>> list.
>>>>>>>>>>>>>>>>> Besides the changes in code architecture, there is also a new
>>>>>>>>>>>>>>>>> feature in
>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>> raster-pipes-2 branch. It is now possible to write through
>>>>>>>>>>>>>>>>> QgsRasterDataProvider (currently only supported by the gdal
>>>>>>>>>>>>>>>>> provider).
>>>>>>>>>>>>>>>>> There
>>>>>>>>>>>>>>>>> is a 'save as...' function also for rasters now (though it is
>>>>>>>>>>>>>>>>> not 100%
>>>>>>>>>>>>>>>>> complete at the moment). There is the option to save a raster
>>>>>>>>>>>>>>>>> in one
>>>>>>>>>>>>>>>>> file or
>>>>>>>>>>>>>>>>> in tiles (the tiles are then saved in one directory and vrt /
>>>>>>>>>>>>>>>>> pyramides
>>>>>>>>>>>>>>>>> are
>>>>>>>>>>>>>>>>> automatically created. Very usefull for saving the contents
>>>>>>>>>>>>>>>>> of a WMS
>>>>>>>>>>>>>>>>> layer).
>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>> Marco
>>>>>>>>>>>>>>>>> Dr. Marco Hugentobler
>>>>>>>>>>>>>>>>> Sourcepole -  Linux & Open Source Solutions
>>>>>>>>>>>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>>>>>>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>>>>>>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>> Qgis-developer mailing list
>>>>>>>>>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>>>>>>>>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>>>>>>>>>>>> Tim Sutton - QGIS Project Steering Committee Member (Release
>>>>>>>>>>>> Manager)
>>>>>>>>>>>> Please do not email me off-list with technical
>>>>>>>>>>>> support questions. Using the lists will gain
>>>>>>>>>>>> more exposure for your issues and the knowledge
>>>>>>>>>>>> surrounding your issue will be shared with all.
>>>>>>>>>>>> Visit http://linfiniti.com to find out about:
>>>>>>>>>>>>   * QGIS programming and support services
>>>>>>>>>>>>   * Mapserver and PostGIS based hosting plans
>>>>>>>>>>>>   * FOSS Consulting Services
>>>>>>>>>>>> Skype: timlinux
>>>>>>>>>>>> Irc: timlinux on #qgis at freenode.net
>>>>>>>> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>>>>>>>> Skype: timlinux
>>>>>> Skype: timlinux
