[Qgis-developer] [QGIS Server] print layout
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Jun 11 04:50:26 PDT 2012
Hi Giovanni
It's something for the qgis-web-client bug tracker. The client needs to use more precise floats for the GetPrint request.
Regards, Marco
Von Samsung Galaxy Note gesendet
-------- Original message --------
Subject: Re: [Qgis-developer] [QGIS Server] print layout
From: Giovanni Manghi <giovanni.manghi at faunalia.pt>
To: Marco Hugentobler <marco.hugentobler at sourcepole.ch>
CC: qgis-developer at lists.osgeo.org
Hi Marco,
On Mon, 2012-06-11 at 12:07 +0200, Marco Hugentobler wrote:
> Hi Giovanni
> I think this is a precision problem (client side). At 1:50:000, the
> GetPrint request looks like that:
> http://mapserver.uevora.pt/cgi-bin/qgis_mapserv.fcgi?map=/var/www/qgis-web-client/projects/helloworld.qgs&SERVICE=WMS&VERSION=1.3&REQUEST=GetPrint&FORMAT=pdf&EXCEPTIONS=application/vnd.ogc.se_inimage&TRANSPARENT=true&SRS=EPSG:4326&DPI=300&TEMPLATE=Composer%201&map0:extent=3.3,8,3.4,8&map0:rotation=0&map0:scale=50000&map0:grid_interval_x=2000&map0:grid_interval_y=2000&LAYERS=Country%2CHello
> So the critical thing is map0:extent=3.3,8,3.4,8 which means the
> height of the map is 0.
thanks for the answer,
it is not clear to me, is then a client issue or a local configuration
one?
cheers
-- Giovanni --
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120611/d23eb136/attachment.html>
