[Qgis-developer] [QGIS Server] print layout
Andreas Neumann
a.neumann at carto.net
Mon Jun 11 06:22:59 PDT 2012
I agree - this has to be fixed in the client. We should add a global
option for that.
The original version was only done for meters, so we did not use more
than one digit after the comma for specifying the print extent.
Can you please open a ticket in the qgis-web-client section?
Thanks,
Andreas
On Mon, 11 Jun 2012 13:50:26 +0200, Marco Hugentobler wrote:
> Hi Giovanni
> It's something for the qgis-web-client bug tracker. The client needs
> to use more precise floats for the GetPrint request.
> Regards, Marco
> Von Samsung Galaxy Note gesendet
> -------- Original message --------
> Subject: Re: [Qgis-developer] [QGIS Server] print layout
> From: Giovanni Manghi
> To: Marco Hugentobler
> CC: qgis-developer at lists.osgeo.org
> Hi Marco,
> On Mon, 2012-06-11 at 12:07 +0200, Marco Hugentobler wrote:
>> Hi Giovanni
>> I think this is a precision problem (client side). At 1:50:000, the
>> GetPrint request looks like that:
> http://mapserver.uevora.pt/cgi-bin/qgis_mapserv.fcgi?map=/var/www/qgis-web-client/projects/helloworld.qgs&SERVICE=WMS&VERSION=1.3&REQUEST=GetPrint&FORMAT=pdf&EXCEPTIONS=application/vnd.ogc.se_inimage&TRANSPARENT=true&SRS=EPSG:4326&DPI=300&TEMPLATE=Composer%201&map0:extent=3.3,8,3.4,8&map0:rotation=0&map0:scale=50000&map0:grid_interval_x=2000&map0:grid_interval_y=2000&LAYERS=Country%2CHello
>> So the critical thing is map0:extent=3.3,8,3.4,8 which means the
>> height of the map is 0.
> thanks for the answer,
> it is not clear to me, is then a client issue or a local
> configuration
> one?
> cheers
> -- Giovanni --
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
