[Qgis-developer] Unit tests failing - a heartfelt plea
Tim Sutton
lists at linfiniti.com
Fri Jun 15 03:29:31 PDT 2012
Hi
On Fri, Jun 15, 2012 at 11:49 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Fri, Jun 15, 2012 at 11:41:58AM +0200, Tim Sutton wrote:
>> You can test your work before pusing it to master by doing:
>> make test
>> make check
Sorry - I wasnt clear - yes one or the other!
> One or the other, right ?
> (should be the other, you know ? :P)
Regards
Tim
> --strk;
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
