[Qgis-developer] Unit tests failing - a heartfelt plea
Radim Blazek
radim.blazek at gmail.com
Fri Jun 15 08:44:29 PDT 2012
I wanted to bisect the first wrong commit after 1.8 but I found that
final-1_8_0 also fails in qgis_rasterlayertest and qgis_rendererstest.
Is it possible? Release was made with broken tests? Is it my local
problem? Are the tests independent of user settings?
OTOH, the results for final-1_8_0 of qgis_rasterlayertest are much
better than latest master.
Radim
On Fri, Jun 15, 2012 at 11:41 AM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi All
> I just want to make a heartfelt plea that any new code pushed to Git
> master should not break tests (at minimum on the platform on which you
> are working). If you do radical changes, the test suite should be
> updated to accommodate them so that the tests still pass for your
> platform when you commit. I would like to see the test suite grow to
> encompass as much functionality of QGIS as possible, but it will be
> very difficult to maintain them if we commit code that breaks them.
> You can always view the state of the last nightly builds here:
> http://dash.orfeo-toolbox.org/index.php?project=QGIS
> You can test your work before pusing it to master by doing:
> make test
> make check
> or (to share your test results)
> make Experimental
> Thanks!
> Regards
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing list
