[Qgis-developer] Unit tests failing - a heartfelt plea
Etienne Tourigny
etourigny.dev at gmail.com
Fri Jun 15 09:44:03 PDT 2012
They were most probably not failing before 1.8 was released, see:
http://dash.orfeo-toolbox.org/index.php?project=QGIS&date=2012-06-13
On Fri, Jun 15, 2012 at 12:53 PM, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
>> OTOH, the results for final-1_8_0 of qgis_rasterlayertest are much
>> better than latest master.
> That's because of the raster_resampler merge. Something to look at for me.
> No idea why they fail before (probably it depends on the GDAL you are
> using).
The autobuilds use a variety of gdal version (1-6 -> 1.9.1) so I think
most possibilities are covered - so it's probably a local problem.
> For me, there is also
> 11/20 Test #11: qgis_geometrytest ....................***Failed 0.44 sec
> and the application hangs with qgis_ziplayertest :
> Start 17: qgis_ziplayertest
> *** glibc detected ***
> /home/marco/src/Quantum-GIS/build/output/bin/qgis_ziplayertest: corrupted
> double-linked list: 0x000000000266fc20 ***
This is after raster_resampler merge right? Which gdal version and OS
are you using?
Please send me a debug log of that test.
> Regards,
> Marco
> Am 15.06.2012 17:44, schrieb Radim Blazek:
>> I wanted to bisect the first wrong commit after 1.8 but I found that
>> final-1_8_0 also fails in qgis_rasterlayertest and qgis_rendererstest.
>> Is it possible? Release was made with broken tests? Is it my local
>> problem? Are the tests independent of user settings?
>> Radim
>> On Fri, Jun 15, 2012 at 11:41 AM, Tim Sutton<lists at linfiniti.com> wrote:
>>> Hi All
>>> I just want to make a heartfelt plea that any new code pushed to Git
>>> master should not break tests (at minimum on the platform on which you
>>> are working). If you do radical changes, the test suite should be
>>> updated to accommodate them so that the tests still pass for your
>>> platform when you commit. I would like to see the test suite grow to
>>> encompass as much functionality of QGIS as possible, but it will be
>>> very difficult to maintain them if we commit code that breaks them.
>>> You can always view the state of the last nightly builds here:
>>> You can test your work before pusing it to master by doing:
>>> make test
>>> make check
>>> or (to share your test results)
>>> make Experimental
>>> Thanks!
>>> Regards
>>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>>> Please do not email me off-list with technical
>>> support questions. Using the lists will gain
>>> more exposure for your issues and the knowledge
>>> surrounding your issue will be shared with all.
>>> Visit http://linfiniti.com to find out about:
>>> * QGIS programming and support services
>>> * Mapserver and PostGIS based hosting plans
>>> * FOSS Consulting Services
>>> Skype: timlinux
>>> Irc: timlinux on #qgis at freenode.net
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole - Linux& Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
