[Qgis-developer] Questions about symbology: ellipse marker, symbol layer properties, default increment
欧阳乐岩
ouyang.leyan at hotmail.com
Sun Jun 17 00:29:20 PDT 2012
Hi all,
Now that I am confident that bug reports and patches are considered
(good response time on the mailing-list by the way !) I started to look
a bit more in the code.
I am currently mostly interested in the symbology code as it is central
to my use of QGis and still has a lot of room for improvement in my
opinion.
I have mainly three questions:
* Why is the ellipse marker separated from the simple marker?
* What is the logic behind the two level of properties? (global
properties for the symbol and then for each symbol layer)
* Can we change the default values for increment?
Why is the ellipse marker separated from the simple marker ? Isn't it
possible to just replace size by sizeX, sizeY (or keep size and add a
ratio if it is judged more intuitive ?) and merge ellipse marker ? Right
now, the situation is that both have advantages and drawbacks. Ellipse
markers allow to control the outline width (but a 0 width does not
work), to use data-defined color, but they do not obey the global color
choice (before going into the symbol properties dialog. This means for
example that they cannot be used for graduated symbology. They also have
less shapes available and cannot be offset like simple symbols.
Is it a temporary situation and both will develop in different
directions later ? Should we merge them ?
Second, what is the logic behind the symbol layers ? I like the concept
as it allows to construct complex symbols easily, but right now the
whole thing is a bit shaky: if I make a symbol with two layers using
some offset and rotations (real-world use case : a valve symbol by using
two triangles touching by one corner), the resulting symbol shape is
affected when I manipulate the angle or the size:
* changing the main rotation will reset all the layers rotation (that
was the object of my first patch http://hub.qgis.org/issues/4453)
* changing the size will scale all layers accordingly and respect their
relative size, but the offset will not be modified so elements that were
just touching each others will start overlapping.
Third, is it possible to change the values for increment of line width
and border width? I know that when I want to increase a line width from
the default 0.26, I very rarely want 1.26, 2.26, 3.26 ... I would love
to have 0.26, 0.3, 0.4, 0.5, etc.
Sorry for the long blurb ! Should I ask someone in particular if I have
subsequent questions ?
Regards,
Leyan
