[Qgis-developer] Unit tests failing - a heartfelt plea
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Mon Jun 18 23:46:20 PDT 2012
>Only one test failed here - qgis_regression992
Looking at the past dashboard results
(http://dash.orfeo-toolbox.org/index.php?project=QGIS), there is a shift
with qgis_regression992 even in the passed tests (with a pixel
difference just under 300, so considered as 'valid').
It was essentially the dpi problem (image at 72 dpi, system dpi usually
at 96). I wonder if it is okay to just replace the image with a
not-shifted one. Opinions?
Regards,
Marco
Am 18.06.2012 20:04, schrieb Alexander Bruy:
> Only one test failed here - qgis_regression992.
> 2012/6/18 Radim Blazek<radim.blazek at gmail.com>:
>> Here (85/86 dpi) it also passes 100% OK.
>> Radim
Dr. Marco Hugentobler
Sourcepole - Linux& Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
