[Qgis-developer] Unit tests failing - a heartfelt plea
Tim Sutton
lists at linfiniti.com
Tue Jun 19 01:17:41 PDT 2012
Hi
On Tue, Jun 19, 2012 at 8:46 AM, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
>> Only one test failed here - qgis_regression992
> Looking at the past dashboard results
> (http://dash.orfeo-toolbox.org/index.php?project=QGIS), there is a shift
> with qgis_regression992 even in the passed tests (with a pixel difference
> just under 300, so considered as 'valid').
> It was essentially the dpi problem (image at 72 dpi, system dpi usually at
> 96). I wonder if it is okay to just replace the image with a not-shifted
> one. Opinions?
Thanks for getting the tests to work again! Yes I think it would be
fine to just update the expected image.
Regards
Tim
> Regards,
> Marco
> Am 18.06.2012 20:04, schrieb Alexander Bruy:
>> Only one test failed here - qgis_regression992.
>> 2012/6/18 Radim Blazek<radim.blazek at gmail.com>:
>>> Here (85/86 dpi) it also passes 100% OK.
>>> Radim
> Dr. Marco Hugentobler
> Sourcepole - Linux& Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
