[Qgis-developer] GGL2 - QGIS integration
Vincent Picavet
vincent.ml at oslandia.com
Wed Jun 20 07:44:34 PDT 2012
Le mercredi 20 juin 2012 16:08:19, Etienne Tourigny a écrit :
> In case of linux systems, I would think that most (if not all)
> installations include java, so it's not that much of a requirement.
> It might be more complicated in the case of windows and mac.
That's really not the case as far as the linux systems I use are concerned...
A java dependency for QGIS would really be a pain.
> It would be interesting to have a separate qgis-framework package (or
> similar name) that includes sextante and its dependencies and modules
> like GGL.
> That way you can install qgis without these requirements.
In any case, you will not want to have a dependency between sextante and all
of its modules.
They are numerous, and growing. It should be the responsibility of the user to
install the modules by itself to enable the sextante support with this module.
Otherwise the next QGIS installer will be 1.5Gb and a nightmare to package.
Vincent
> Etienne
> On Wed, Jun 20, 2012 at 9:56 AM, Tim Sutton <lists at linfiniti.com> wrote:
> > Hi
> > On Wed, Jun 20, 2012 at 1:05 PM, G. Allegri <giohappy at gmail.com> wrote:
> >>> Are there any plans to make a C++ or Python port of GGL? From looking
> >>> at the website it looks like the user will need java on their system
> >>> to use it?
> >> AFAIU the plan are to keep it in Java, at now. The QGis integration idea
> >> are:
> >> 1 - a plugin to "serve" QGis as a GIS to GGL2 (read/load layers)
> >> 2 - (if they're will be foundings) run GGL2 commands from Sextante.
> >> It would be nice to have a C++/Python porting, but it would require a
> >> lot of coding, I suppose...
> > I guess its obvious why I asked, but in case it isn't, GGL seems
> > really cool, like something that we should ship with QGIS and SEXTANTE
> > but the java depency will probably always relegate it to a non-bundled
> > functionality (unless we can get broad agreement to make java a
> > dependency on your system when installing QGIS).
> > Regards
> > Tim
> >> giovanni
> >>> Regards
> >>> Tim
> >>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> >>> Please do not email me off-list with technical
> >>> support questions. Using the lists will gain
> >>> more exposure for your issues and the knowledge
> >>> surrounding your issue will be shared with all.
> >>> Visit http://linfiniti.com to find out about:
> >>> * QGIS programming and support services
> >>> * Mapserver and PostGIS based hosting plans
> >>> * FOSS Consulting Services
> >>> Skype: timlinux
> >>> Irc: timlinux on #qgis at freenode.net
> > Skype: timlinux
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
