[Qgis-developer] Official QGIS crashes on startup: EarthBeat, ValueTool plugins?
Etienne Tourigny etourigny.dev at gmail.com
Sat Jun 23 08:11:12 PDT 2012
Does this mean that qwt inside qgis core (c++) should be deprecated?
The histogram plot uses qwt, and I have made some modifications to use
a picker and a zoomer using qwt (in a pending pull request).
Cheers,
Etienne
On Thu, Jun 21, 2012 at 8:44 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> It may be the same problem as on OS X?  PyQwt needed by valueTool (and profileTool, others) is not compatible with the latest PyQt, and probably never will be.  Plugins using PyQwt need to find another toolbox.
> On Jun 21, 2012, at 1:10 PM, Paolo Cavallini wrote:
>> Hi all.
>> I remove my custom packaged qgis, and installed the official one, on debian unstable,
>> from qgis.org. It crashes on startup, but with --noplugin it is ok.
>> Reactivating plugins, it apparently crashes when activating EarthBeat or ValueTool
>> plugins. The same plugins were running fine in my self compiled version. No message
>> from the console, just "Errore di segmentazione".
>> Any hint?
>> All the best.
>> Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> Nuovi corsi: http://www.faunalia.it/calendario
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
