[Qgis-developer] Official QGIS crashes on startup: EarthBeat, ValueTool plugins?
William Kyngesburye
woklist at kyngchaos.com
Sat Jun 23 08:52:13 PDT 2012
Qwt itself is good.
As I understand it, Qwt 6 has active development, but I haven't tried it with QGIS. 5.2 stills works fine in QGIS. PyQwt uses Qwt 5.2 and will not be updated for Qwt 6, and it doesn't look like it will be fixed to work with recent PyQt versions.
On Jun 23, 2012, at 10:11 AM, Etienne Tourigny wrote:
> Does this mean that qwt inside qgis core (c++) should be deprecated?
> The histogram plot uses qwt, and I have made some modifications to use
> a picker and a zoomer using qwt (in a pending pull request).
> Cheers,
> Etienne
> On Thu, Jun 21, 2012 at 8:44 PM, William Kyngesburye
> <woklist at kyngchaos.com> wrote:
>> It may be the same problem as on OS X? PyQwt needed by valueTool (and profileTool, others) is not compatible with the latest PyQt, and probably never will be. Plugins using PyQwt need to find another toolbox.
>> On Jun 21, 2012, at 1:10 PM, Paolo Cavallini wrote:
>>> Hi all.
>>> I remove my custom packaged qgis, and installed the official one, on debian unstable,
>>> from qgis.org. It crashes on startup, but with --noplugin it is ok.
>>> Reactivating plugins, it apparently crashes when activating EarthBeat or ValueTool
>>> plugins. The same plugins were running fine in my self compiled version. No message
>>> from the console, just "Errore di segmentazione".
>>> Any hint?
>>> All the best.
>>> Paolo Cavallini - Faunalia
>>> www.faunalia.eu
>>> Full contact details at www.faunalia.eu/pc
>>> Nuovi corsi: http://www.faunalia.it/calendario
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
>> - Hitchhiker's Guide to the Galaxy
"Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
