[Qgis-developer] valuetool crashes qgis
Vincent Schut schut at sarvision.nl
Thu Jun 28 02:56:36 PDT 2012
OK, so I tried to recompile qgis from an emptied build dir, but ccmake
gives me this error while configuring:
CMake Error: The following variables are used in this project, but they
are set to NOTFOUND.
  Please set them or make sure they are set and tested correctly in the
CMake files:
  PYTHON_LIBRARY
      linked by target "qgispython" in directory
/usr/local/src/qgis/src/python
      linked by target "python_module_qgis_analysis" in directory
/usr/local/src/qgis/python
      linked by target "python_module_qgis_core" in directory
      linked by target "python_module_qgis_gui" in directory
      linked by target "python_module_qgis_networkanalysis" in directory
could that have anything to do with it? Qgis used to build fine, and I
definitely have python and pyqt installed. Or is this just because I
have both python2.7 and python3.2 installed?
btw, the source folder was updated from git just yesterday.
best,
Vincent.
On 06/28/2012 10:51 AM, Paolo Cavallini wrote:
> Il 28/06/2012 08:38, Vincent Schut ha scritto:
>> Hi,
>> is it just me, or is the valuetool plugin crashing qgis (current git build) when
>> loading the plugin?
> I had the same problem, and it turned out being a packaging problem (different pyqt
> versions). recompiling solved it.
> All the best.
