[Qgis-developer] Removing old labelling
Andreas Neumann a.neumann at carto.net
Mon Mar 5 11:06:16 EST 2012
 We discussed this issue backwards and forwards and it would be good to
 make some progress here. There is really not a lot missing in the new
 labeling and I don't agree with Paolo that the new labeling is slower
 than the old labeling. It may have different settings and thus people
 are comparing apples with oranges.
 It would be good to integrate the labeling 2.0 in the layers dialogue
 and make it the default.
 If someone is missing a feature in labeling 2.0 that is present in
 labeling 1.0 he/she should either work on it or pay someone to work on
 it. It is not good blocking labeling 2.0 just because some minor aspect
 is missing.
 What are the real issues/problems with labeling 2.0?
 Andreas
 On Mon, 5 Mar 2012 22:30:51 +1000, Nathan Woodrow wrote:
> On Mon, Mar 5, 2012 at 10:16 PM, Jürgen E.  wrote:
>> I'd say the new labeling should also be integrated into the vector
>> layer
>> properties (not sure if there is something implementationwise that
>> is an
>> obstacle to that).   In that case we also could have a switch
>> mechanism like
>> between old and new labeling.
> I'd support this idea. This would help remove the confusion, or at
> least hide it, until we can remove it in 2.0.  We could do what we
> did with the symbologly and set it to you use new labelling by
> default.
> I don't mind having the toolbar button but we could change it to
> just launch the properties -> Labels tab.
> - Nathan
> Links:
> [1] mailto:jef at norbit.de
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
