[Qgis-developer] Removing old labelling
bernhard.stroebl at jena.de
Tue Mar 6 08:26:39 EST 2012
I cannot confirm slow polygon labelling
~42000 parcels (polygon) stored in a PostGIS DB (remote)
each labelled with its parcel number over centroid between scales 1:1: -
1:4000
labels instantly on
1) an Intel Core2 Duo 2.2GHz 2GB RAM runnning WinXP/QGIS 1.7.1
2) an Intel QuadCore 2.80 GHz 4GB RAM running OpenSuse 64bit/QGIS 1.7.4
Bernhard
Am 06.03.2012 14:18, schrieb Andreas Neumann:
> So - as I understand it - only area features are labeled slowly while
> the speed of point and line labeling is fast enough, correct?
> If this is the issue I can tell you that Martin Dobias is currently
> working on improving the speed of area feature labeling. So improvements
> in this respect should appear soon.
> Andreas
> On Tue, 6 Mar 2012 13:42:03 +0100, wrote:
>> -----Werner Macho <werner.macho at gmail.com> ha scritto: -----
>>> Per: luca_manganelli at comune.trento.it
>>> Da: Werner Macho <werner.macho at gmail.com>
>>> Data: 06/03/2012 01.31PM
>>> Cc: qgis-developer at lists.osgeo.org
>>> Oggetto: Re: [Qgis-developer] Removing old labelling
>>> Any way to find the bottleneck?
>>> It would be real nice to have the new labeling replacing the old one.
>>> Redundancy is nice.. but not forever.
>>> I wish i could find the bottleneck myself..
>> Try it with many (>500) polygon shapes. It takes ages on a dual
>> core._______________________________________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
________ Information from NOD32 ________
This message was checked by NOD32 Antivirus System for Linux Mail Server.
http://www.nod32.com
