[Qgis-developer] Libeay32 dll version conflict
Andreas Neumann
a.neumann at carto.net
Tue Mar 6 10:48:56 EST 2012
Thanks Jürgen.
Everything works fine by copying the libeay32.dll into apps\qgis-dev\bin\
I also found out what other software caused the conflict. It is Abacus - the accounting software our city id using.
Thanks again Andreas.
Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail gesendet.
Andreas Neumann <a.neumann at carto.net> schrieb:
Hi Jürgen,
Do you know in which directories I need to place the libeay32.dll?
Would it be the directory where the qgis.exe file resides - e.g.
C:\Program Files\OSGeo4W\apps\qgis-dev\bin ?
Thanks,
Andreas
On Wed, 29 Feb 2012 15:28:39 +0100, Jürgen E. Fischer wrote:
> Hi Andreas,
> On Wed, 29. Feb 2012 at 14:08:22 +0100, Andreas Neumann wrote:
>> Every once in a while I get a dll version conflict when starting
>> QGIS. Seems
>> like Windows has a newer version of libeay32.dll in \winnt\system32
>> whereas
>> OSGeo4W has a different (older?) version in
>> C:\Programme\OSGeo4W\bin
> The DLL doesn't belong to Windows, but to some other software that
> also uses
> OpenSSL and put the DLL there.
>> Anybody knows why there is this version conflict? The system wide
>> libeay32.dll - does it have priority over the one in OSGeo4W? Or is
>> there
>> some setting I can use?
> Unfortunately the system32 directory has priority and is processed
> before PATH
> is searched (see also [1]). AFAIK the only way is to (re)move the
> DLL from
> system32 or to put the OSGeo4W version into each osgeo4w directory
> where
> executables that load it are.
> Jürgen
> [1] http://trac.osgeo.org/osgeo4w/ticket/35
> Jürgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
> +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
_____________________________________________
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120306/67caa53d/attachment.html
