[Qgis-developer] idea for settings
Denis Rouzaud
denis.rouzaud at gmail.com
Fri Mar 9 05:42:43 EST 2012
Hi all,
I just wanted to share an idea I had today. In my plugins, I always had
the problem of never knowing the default values I had set for the
settings (the info being spread all over the code files), and it was
always a pain to change a default value (I had to search in all my files
for all the calls for the setting in question).
So, I created a class with a fake inheritance of QSettings:
class MyPluginSettings():
def __init__(self):
self.settings = QSettings("MyPlugin","MyPlugin")
self.defaultValue = { "mySettingValue1" : 0,
"SomeTextSetting" : "hello",
"Value4" : 13
def value(self,setting):
if self.defaultValue.has_key(setting) is False:
raise NameError('MyPlugin has no setting %s' % setting)
return self.settings.value(setting,self.defaultValue.get(setting))
def setValue(self,setting,value):
self.settings.setValue(setting,value)
You set self.settings = MyPluginSettings() in your plugin, and when you
do self.settings.value("mySettingValue1"), you don't need to specify the
default value.
The class will raise an exception if you call for an undefined setting.
This will avoid typos in settings calls and therefore multiple
definitions of the same setting.
Don't know if it's useful for you, but I was quite happy with this
solution....
Greetings,
Denis
