[Qgis-developer] idea for settings
Alexandre Badez
alexandre.badez at gmail.com
Fri Mar 9 05:49:54 EST 2012
By the way instead of:
if self.defaultValue.has_key(setting) is False
You should write this:
if setting not in self.defaultValue:
It's more "pythonic" and work with list, tuple, set and every things
that implement the __contains__ method (
http://docs.python.org/reference/datamodel.html?highlight=__contains__#object.__contains__
On Fri, Mar 9, 2012 at 11:42, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi all,
> I just wanted to share an idea I had today. In my plugins, I always had the
> problem of never knowing the default values I had set for the settings (the
> info being spread all over the code files), and it was always a pain to
> change a default value (I had to search in all my files for all the calls
> for the setting in question).
> So, I created a class with a fake inheritance of QSettings:
> class MyPluginSettings():
> def __init__(self):
> self.settings = QSettings("MyPlugin","MyPlugin")
> self.defaultValue = { "mySettingValue1" : 0,
> "SomeTextSetting" : "hello",
> "Value4" : 13
> def value(self,setting):
> if self.defaultValue.has_key(setting) is False:
> raise NameError('MyPlugin has no setting %s' % setting)
> return self.settings.value(setting,self.defaultValue.get(setting))
> def setValue(self,setting,value):
> self.settings.setValue(setting,value)
> You set self.settings = MyPluginSettings() in your plugin, and when you do
> self.settings.value("mySettingValue1"), you don't need to specify the
> default value.
> The class will raise an exception if you call for an undefined setting. This
> will avoid typos in settings calls and therefore multiple definitions of the
> same setting.
> Don't know if it's useful for you, but I was quite happy with this
> solution....
> Greetings,
> Denis
> Qgis-developer mailing list
Alex
