[Qgis-developer] idea for settings
Denis Rouzaud
denis.rouzaud at gmail.com
Fri Mar 9 05:55:15 EST 2012
Thanks a lot for the tip!
On 03/09/2012 11:49 AM, Alexandre Badez wrote:
> Hi,
> By the way instead of:
> if self.defaultValue.has_key(setting) is False
> You should write this:
> if setting not in self.defaultValue:
> It's more "pythonic" and work with list, tuple, set and every things
> that implement the __contains__ method (
> http://docs.python.org/reference/datamodel.html?highlight=__contains__#object.__contains__
> On Fri, Mar 9, 2012 at 11:42, Denis Rouzaud<denis.rouzaud at gmail.com> wrote:
>> Hi all,
>> I just wanted to share an idea I had today. In my plugins, I always had the
>> problem of never knowing the default values I had set for the settings (the
>> info being spread all over the code files), and it was always a pain to
>> change a default value (I had to search in all my files for all the calls
>> for the setting in question).
>> So, I created a class with a fake inheritance of QSettings:
>> class MyPluginSettings():
>> def __init__(self):
>> self.settings = QSettings("MyPlugin","MyPlugin")
>> self.defaultValue = { "mySettingValue1" : 0,
>> "SomeTextSetting" : "hello",
>> "Value4" : 13
>> def value(self,setting):
>> if self.defaultValue.has_key(setting) is False:
>> raise NameError('MyPlugin has no setting %s' % setting)
>> return self.settings.value(setting,self.defaultValue.get(setting))
>> def setValue(self,setting,value):
>> self.settings.setValue(setting,value)
>> You set self.settings = MyPluginSettings() in your plugin, and when you do
>> self.settings.value("mySettingValue1"), you don't need to specify the
>> default value.
>> The class will raise an exception if you call for an undefined setting. This
>> will avoid typos in settings calls and therefore multiple definitions of the
>> same setting.
>> Don't know if it's useful for you, but I was quite happy with this
>> solution....
>> Greetings,
>> Denis
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
