[Qgis-developer] plugin bug and patch - RGB composition plugin
broken in 1.7.4 and master
Etienne Tourigny
etourigny.dev at gmail.com
Fri Mar 9 14:25:02 EST 2012
Also, the "build virtual raster" tool does not work if a file has
sublayers (GDAL subdatasets), such as HDF4 or netcdf.
I have implemented a fix for this and submitted it as pull request
#101 (among other fixes)
Regards,
Etienne
On Thu, Mar 8, 2012 at 10:26 AM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> I agree that the gdaltools "buils virtual raster" has more options,
> but the rgb composition plugin is nicer because you can select
> existing layers instead of have to open the input files. Perhaps this
> could be added to gdaltools?
> Etienne
> On Thu, Mar 8, 2012 at 5:32 AM, Zirneklitis <eko at lanet.lv> wrote:
>> I suppose the RGB composition plug-in should be considered as depreciated.
>> GdalTools plug-in must be used instead (Raster/Miscellaneous/Build Viirtual
>> Raster). The result is the same but with more options.
>> Best regards,
>> Karlis
>> Etienne Tourigny wrote:
>>> The RGB composition plugin does not work (throws error below when
>>> operation is requested)
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
