[Qgis-developer] plugin bug and patch - RGB composition plugin broken in 1.7.4 and master
Etienne Tourigny etourigny.dev at gmail.com
Thu Mar 8 08:26:02 EST 2012
I agree that the gdaltools "buils virtual raster" has more options,
but the rgb composition plugin is nicer because you can select
existing layers instead of have to open the input files.  Perhaps this
could be added to gdaltools?
Etienne
On Thu, Mar 8, 2012 at 5:32 AM, Zirneklitis <eko at lanet.lv> wrote:
> I suppose the RGB composition plug-in should be considered as depreciated.
> GdalTools plug-in must be used instead (Raster/Miscellaneous/Build Viirtual
> Raster). The result is the same but with more options.
> Best regards,
> Karlis
> Etienne Tourigny wrote:
>> The RGB composition plugin does not work (throws error below when
>> operation is requested)
> Qgis-developer mailing list
