[Qgis-developer] plugin bug and patch - RGB composition plugin
broken in 1.7.4 and master
Zirneklitis
eko at lanet.lv
Thu Mar 8 03:32:11 EST 2012
I suppose the RGB composition plug-in should be considered as
depreciated. GdalTools plug-in must be used instead
(Raster/Miscellaneous/Build Viirtual Raster). The result is the same but
with more options.
Best regards,
Karlis
Etienne Tourigny wrote:
> The RGB composition plugin does not work (throws error below when
> operation is requested)
