[Qgis-developer] print layout: various issues
Andreas Neumann a.neumann at carto.net
Sun Mar 18 04:42:38 EDT 2012
Hi Paolo,
Before, QGIS rendered the SVG files during startup - which was even
worse in my opinion - because often you would open a project and don't
want to print. Somehow it would be great if we could find a way to cache
the rendered SVGs from one session to the next.
We have a student here in Switzerland interested in working on improving
the SVG symbol situation - maybe we can find a better solution as part
of this project - if it is accepted.
Andreas
On 03/16/2012 08:57 PM, Paolo Cavallini wrote:
> Hi all.
> In current master I found a couple of issues using the Print Layout:
> - generating the preview for svg images takes a very long time; a known
> problem, but quite annoying on slow machines
> - the right panel for images to add is much wider than others, so it
> does not fit small (<1280) screens.
> All the best.
