[Qgis-developer] Scripting QGIS from the outside using Python
Nathan Woodrow
madmanwoo at gmail.com
Mon Mar 19 09:17:25 EDT 2012
Thanks Marco, that's pretty much what I needed.
- Nathan
On Mon, Mar 19, 2012 at 5:37 PM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
> Hi Nathan
> >What I have seen so far looks like you have to handle recreating the
> composer and all its items using the xml like in
> There has been some rearrangement in the composer classes (the first API
> break :-) ). With git master version, you should be able to create a
> QgsComposition by calling its readXML Method, then call
> QgsComposition::readItemsFromXML.
> The composer is a bit of a special case because it is possible to replace
> label strings, map extent / layer / rotation with parameters. And with the
> legend, there is a workaround to avoid using the x-server. So with an
> external python script, I'd recommend to use
> Regards,
> Marco
> On 19.03.2012 01:22, Nathan Woodrow wrote:
> Martin,
> It's not so much that I don't know how to create a new composer from
> Python more that I don't now how to restore a composer item from the
> project file using Python.
> I'm using the project file that contains composers as a template which I
> need to open and print. What I have seen so far looks like you have to
> handle recreating the composer and all its items using the xml like in
> https://github.com/qgis/Quantum-GIS/blob/master/src/mapserver/qgsprojectparser.cpp
> Maybe the composer object could do with a createFromXML() method which
> constructs a composer, and all its children, as per the project file.
> - Nathan
> On Mon, Mar 19, 2012 at 4:51 AM, Martin Dobias <wonder.sk at gmail.com>wrote:
>> On Thu, Mar 15, 2012 at 2:29 PM, Nathan Woodrow <madmanwoo at gmail.com>
>> wrote:
>> > Is it possible to:
>> > Load QGIS from Python (well I know how to do this using
>> > QgsApplicaiton.Init())
>> > Open the project file
>> > Zoom to a location
>> > Print the first composer to pdf
>> > OR render out the map canvas to a image.
>> Hi Nathan
>> yes that's all possible from an external python script with PyQGIS,
>> without actually starting GUI.
>> > From what I can see the only way is to create a new composer item and
>> pass
>> > it the composer node from the xml.
>> No need to play with XML, everything can be done using API, there is
>> an example in the cookbook:
>> http://qgis.org/pyqgis-cookbook/composer.html
>> Martin
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120319/9f44fa08/attachment.html
