[Qgis-developer] Re: Scripting QGIS from the outside using Python
Stefan Keller sfkeller at gmail.com
Fri Mar 23 10:42:13 EDT 2012
This discussion goes somewhat similar as it was in the "dark days of
hacking" when there was no requirement to add a unit test in new
contributions to mature projects: Of course the code works without and
it hopefully does its job for the contributor. But then, the arguments
succeeded that it's the original author - i.e. who knows the code best
- which the one who should add the unit tests too.
-Stefan
2012/3/23 Jürgen E. <jef at norbit.de>:
> Hi Nathan,
> On Fri, 23. Mar 2012 at 17:20:59 +1000, Nathan Woodrow wrote:
>>    I'm thinking,  Is there some way to scan the public C++ API and check if
>>    it has a sip binding?
> At least none that I know of - assuming you mean something automatic ;)
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden               http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
