[Qgis-developer] Re: Scripting QGIS from the outside using Python
Marco Hugentobler marco.hugentobler at sourcepole.ch
Tue Mar 20 03:33:56 EDT 2012
Hi Stefan
>What could we do that the C++ API is better covered by Python bindings?
You could add sip files.
>Would'nd it be wise to allow at least new code only being included in
>a stable QGIS version when there exists a corresponding Python bindig
>(.SIP file)
In the case of the triangulation,
such a bureaucratic rule would successfully have kept away the code from
going into QGIS at all.
Regards,
Marco
On 19.03.2012 21:42, Stefan Keller wrote:
> Hi
> 2012/3/19 TheGeographer<dalura86 at googlemail.com>:
>> Marco Hugentobler-4 wrote
>>>> 2.)TIN creation with points
>>> This is possible with QGIS (DualEdgeTriangulation in qgis_analysis, used
>>> by interpolation plugin). There is however no python binding for it, so
>>> only accessible for C++ plugins.
>> Well this sounds very confusing to me :-(
>> Can you give me an advice how to develope this on the easiest way?
> I have no direct advice to you but a hint to the QGIS devs:
> (.SIP file)?
> -Stefan
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
