[Qgis-developer] direct mdb read in QGis?
Giovanni Manghi
giovanni.manghi at gmail.com
Tue Mar 20 12:32:27 EDT 2012
if you use QGIS compiled against gdal 1.9 (as it is now in osgeo4w)
you'll get out of the box support for the personal geodatabase format. I
just tested and it seems to work fine.
cheers
-- Giovanni --
On Tue, 2012-03-20 at 09:30 -0700, haubourg wrote:
> Hi all,
> For my own use, I access mdb's through ODBC access and it works fine. It is
> not quite user-friendly since you first have to define a user or system dsn
> and then fill the connection form in qgis.
> Bigger problem for me, I deployed QGis on 5 Citrix servers (300 users), and
> user-defined-DSN's are disabled for security reasons.. Access to the MS DSN
> manager is locked too..
> *So I have no way to allow qgis users to read MS Access mdb's. *
> I have seen that OGR 1.9 allows optionnal direct access connections:
> http://www.gdal.org/ogr/drv_mdb.html http://www.gdal.org/ogr/drv_mdb.html .
> So, my question: Is it reasonnable (technically) to ask for direct access to
> mdb's databases in Qgis? Is it hard work or not? Do we need to use Java
> Jackcess library as mentionned in OGR doc? Is it an OGR issue instead of
> Qgis?
> I would be pleased to know if I'm alone with this concern.. thanks for your
> feedbacks
> /NB: I do want classical access to non geographical tables and not esri's
> mdb layers. /
> View this message in context: http://osgeo-org.1560.n6.nabble.com/direct-mdb-read-in-QGis-tp4637313p4637313.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
