[Qgis-developer] Pyton Script from Qgis Console Help
vinayan mp vinayan123 at gmail.com
Wed Mar 21 10:17:32 EDT 2012
Hi Asahi,
Thanks a lot for taking your time to review. Appreciate uploading the
edited file. Helped me a lot. And the new script-runner  plugin is simply
stunning.
Thank you
Vinayan
On Wed, Mar 21, 2012 at 8:56 AM, ASAHI Kosuke <asahi at hcc.co.jp> wrote:
> Hi Vinayan
> I can run your script on qgis 1.7.4,
> but I change few points adapt to script runner plugin(see following link).
> http://spatialgalaxy.net/2012/**01/29/script-runner-a-plugin-**
> to-run-python-scripts-in-qgis/<http://spatialgalaxy.net/2012/01/29/script-runner-a-plugin-to-run-python-scripts-in-qgis/>
> Please run this script on script runner.
>  http://d.hatena.ne.jp/waigani/**files/rotate.py?d=download<http://d.hatena.ne.jp/waigani/files/rotate.py?d=download>
> If you have crash again, I need more infomation (OS? version? etc..).
> (2012/03/21 1:14), vinayan wrote:
>> Hi all,
>> I just read about running python scrips from Qgis Console(article by
>> Gary Sherman
>> http://spatialgalaxy.net/2012/**01/27/qgis-running-scripts-in-**
>> the-python-console/<http://spatialgalaxy.net/2012/01/27/qgis-running-scripts-in-the-python-console/>
>> I am trying rotate each point in a layer based on a center point. I
>> managed some code by copying from the CadTools plugin(by Stefan
>> Ziegler). Whenever i run this from qgis console, it crashes the
>> application. Can somebody point me in the right direction? Please find
>> the code below. I have to admit that i started python only yesterday.
>> Note: I am not sure if this is the place to ask this. But i have been
>> inspired by reading
>> #!/usr/bin/env Python
>> """Load all shapefiles in a given directory.
>> This script (iteratefeature.py) runs from the QGIS Python console.
>>  From the console, use:
>> from iteratefeature import Looper
>> ldr = Looper(qgis.utils.iface)
>> ldr.LoopXY()
>> from glob import glob
>> from os import path
>> from qgis.core import *
>> import math
>> class Looper:
>> def __init__(self, iface):
>> """Initialize using the qgis.utils.iface
>> object passed from the console.
>> self.iface = iface
>> def LoopXY(self):
>> basePoint=QgsPoint(-121.**3140824, 38.63196648)
>> rotAngle=45
>> mc = self.iface.mapCanvas()
>> layer = mc.layer(0)
>> provider = layer.dataProvider()
>> feat = QgsFeature()
>> provider.select()
>> while(provider.nextFeature(**feat)):
>> #layer.startEditing()
>> geometry = feat.geometry()
>> geom1=rotate(geometry,**basePoint,rotAngle * math.pi / 180)
>> layer.changeGeometry(feat.id()**, geom1)
>> #feat.setGeometry(geom1)
>> #print "X Coord %d: " %geometry.asPoint().x()
>> #print "Y Coord %d: " %geometry.asPoint().y()
>> layer.commitChanges()
>> print "updated %d: " %feat.id()
>> print
>> # Rotate script
>> def rotate(geometry, point, angle):
>> if angle == 0 or angle == 2 * math.pi or angle == -2 * math.pi:
>> return geom
>> p0 = geometry.asPoint()
>> p1 = QgsPoint(p0.x() - point.x(), p0.y() - point.y())
>> p2 = rotatePoint(p1, angle)
>> p3 = QgsPoint(point.x() + p2.x(), point.y() + p2.y())
>> return QgsGeometry().fromPoint(p3)
>> # Rotates a single point (centre 0/0).
>> # (c) Stefan Ziegler
>> def rotatePoint(point, angle):
>> x = math.cos(angle)*point.x() - math.sin(angle)*point.y()
>> y = math.sin(angle)*point.x() + math.cos(angle)*point.y()
>> return QgsPoint(x, y)
>> Regards
>> Vinayan
>> ______________________________**_________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> ASAHI Kosuke
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120321/5bbd94a5/attachment-0001.html
