[Qgis-developer] gsoc 2012
Victor Olaya
volayaf at gmail.com
Thu Mar 22 05:36:19 EDT 2012
Please, don't consider this a stable version. While most things are
kinda finished and work, I am still changing small thing that might
affect how it works. For instance, I tried to incorporate afew lines
of code to avoid SEXTANTE showing layers from remote services...but
ended up blocking all layers (which might explain what an user
commented before...)
As soon as I have it more or less ready to test (that means, surely
with bugs but not with unfinished stuff), i will for sure use the
plugins repository
Also, I am mostly testing things on windows, and, since it calls other
apps using the command-line, there might be big differences. However,
i hope they are easy to solve, and i prefer to concentrate on the
framework itself now.
Thanks for your support
Regards
El día 22 de marzo de 2012 07:34, Paolo Cavallini
<cavallini at faunalia.it> escribió:
> Il 21/03/2012 23:59, Noli Sicad ha scritto:
>> Is SEXTANTE plugin live now?
>> Anyway, we can browse the python code here.
>> http://sextante.googlecode.com/svn/trunk/soft/bindings/qgis-plugin/
> Victor, so you have rewritten all sextante in python? Wow!
> Or there is a "Save as Python" menu in Eclipse? ;)
> Victor, could you please package it ad add it to http://plugins.qgis.org/ ?
> In this way you'll have a much earlier and wider testing.
> If you need it, we have a script to autogenerate the package.
> All the best, and thanks a lot.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Qgis-developer mailing list
