[Qgis-developer] gsoc 2012
G. Allegri giohappy at gmail.com
Thu Mar 22 06:33:55 EDT 2012
Consider me a tester ASAP you're ready ;)
giovanni
2012/3/22 Victor Olaya <volayaf at gmail.com>
> Please, don't consider this a stable version. While most things are
> kinda finished and work, I am still changing small thing that might
> affect how it works. For instance, I tried to incorporate afew lines
> of code to avoid SEXTANTE showing layers from remote services...but
> ended up blocking all layers (which might explain what an user
> commented before...)
> As soon as I have it more or less ready to test (that means, surely
> with bugs but not with unfinished stuff), i will for sure use the
> plugins repository
> Also, I am mostly testing things on windows, and, since it calls other
> apps using the command-line, there might be big differences. However,
> i hope they are easy to solve, and i prefer to concentrate on the
> framework itself now.
> Thanks for your support
> Regards
> El día 22 de marzo de 2012 07:34, Paolo Cavallini
> <cavallini at faunalia.it> escribió:
> > Il 21/03/2012 23:59, Noli Sicad ha scritto:
> >> Is SEXTANTE plugin live now?
> >> Anyway, we can browse the python code here.
> >> http://sextante.googlecode.com/svn/trunk/soft/bindings/qgis-plugin/
> > Victor, so you have rewritten all sextante in python? Wow!
> > Or there is a "Save as Python" menu in Eclipse? ;)
> > Victor, could you please package it ad add it to
> http://plugins.qgis.org/ ?
> > In this way you'll have a much earlier and wider testing.
> > If you need it, we have a script to autogenerate the package.
> > All the best, and thanks a lot.
> > Paolo Cavallini - Faunalia
> > www.faunalia.eu
> > Full contact details at www.faunalia.eu/pc
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120322/3c723b15/attachment.html
