[Qgis-developer] Re: Edit ticket #5109
Salvatore Larosa lrssvtml at gmail.com
Thu Mar 22 20:37:24 EDT 2012
Il giorno ven, 23/03/2012 alle 08.26 +1000, Nathan Woodrow ha scritto:
> Hey,
> I suspect that you haven't got edit rights for the ticket.  Although
> you should if you made it.
> What were you trying to do?
I was trying to change the ticket priority from normal to high!
I can not edit MULTIPOLYGON geometries stored in postgis,
I would understand if this is just my problem or if someone else has the
same issue!
Regards!
