Hi all. Testing the plugin. A couple of issues: - only map units can be used for distance; would it be possible to use also pixel? - the max length is only 3 digits; it would be good to use also larger numbers. Thanks. -- Paolo Cavallini - Faunalia www.faunalia.eu Full contact details at www.faunalia.eu/pc
