[Qgis-developer] intersect it plugin
Denis Rouzaud
denis.rouzaud at gmail.com
Fri Mar 23 09:11:14 EDT 2012
Hi Paolo,
Thanks a lot for the feedback.
1. I don't really see the interest of using pixels for distance. In what
case would it be needed? I think it is very unlikely we'll have measure
in pixels. Do you have any example?
2. I suggest to set this by setting. I'll put an option to give number
of digits for the distance. What do you think?
3. Did you had any other trouble to understand the plugin? I am not sure
it is really easy to use, bu I don't know how to make it simpler...
Thanks again
Denis
On 03/23/2012 12:16 PM, Paolo Cavallini wrote:
> Hi all.
> Testing the plugin. A couple of issues:
> - only map units can be used for distance; would it be possible to use also pixel?
> - the max length is only 3 digits; it would be good to use also larger numbers.
> Thanks.
