[Qgis-developer] RE: ECW!!!
Even Rouault even.rouault at mines-paris.org
Fri Mar 23 09:15:26 EDT 2012
Selon Fred ETHEVE <fred.etheve at wanadoo.fr>:
> Thank you, all,
> ECW/win was OK with trunk (1.9.90) until 2 days before new nightly...
> perhaps, since, gdal used has been 1.9???!!!
Yes, you should perhaps open a ticket (if not already done by someone else) in
OSGeo4W trac instance to ask for the gdal-ecw plugin to be regenerated against
GDAL 1.9
> It's time to have an opensource wavelets compression!!!
> 1) Somebody knows Epsilon CW? Is -it possible with GDAL1.9 linux and win?
Yes, but the Epsilon lib won't read ECWs and you have probably to build GDAL
yourself against it because few packages will build it.
> 2) How to grab one of the builds available at
> http://www.gisinternals.com/sdk/, have you a method?
Yes, just click on the links ;-) More seriously, what stops you ? You can for
example try
http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1500-gdal-1-9-mapserver-6-0.zip
and download both release-1500-gdal-1-9-mapserver-6-0.zip and
gdal-19-1500-ecw.msi . Note that the builds from that site won't probably
integrate well with qgis, but you can at least do offline conversions with them.
> Best regards
> Fred
> -----Message d'origine-----
> De : Jože Detečnik [mailto:joze.detecnik at jkp-sg.si]
> Envoyé : vendredi 23 mars 2012 07:17
> À : 'Fred ETHEVE'
> Cc : 'qgis-developer'
> Objet : RE: [Qgis-developer] RE: ECW!!!
> Hello,
> On Windows we work with ECW a long time and work very well. (QGIS 1.7.4, GDAL
> 1.8). Currently it's a problem on GDAL 1.9 and trunk versions because ECW
> GDAL plugin  not exist.
> Regards, Joze
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org
> [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Fred ETHEVE
> Sent: Thursday, March 22, 2012 8:56 PM
> To: 'qgis-developer'
> Subject: [Qgis-developer] RE: ECW!!!
> Hi all,
> Big, big problem in France with ECW!
> A lot of my students work with QGIS, and French IGN give rasters in  ECW
> formats Exists a solution to use ECW? Compiling gdal???
> Regards,
> Fred
> Qgis-developer mailing list
