[Qgis-developer] RE: ECW!!!
Fred ETHEVE
fred.etheve at wanadoo.fr
Fri Mar 23 13:15:41 EDT 2012
May we develop an Opensource .ECW, for example .OCW, with sources of
epsilon!?
Because working with larges rasters as 100 000 x 100 000 is now current, and
it's not easy to manipulate .TIF > 30 Go!
Best regards
-----Message d'origine-----
De : Even Rouault [mailto:even.rouault at mines-paris.org]
Envoyé : vendredi 23 mars 2012 14:15
À : Fred ETHEVE
Cc : 'Jože DeteÄnik'; 'qgis-developer'
Objet : RE: [Qgis-developer] RE: ECW!!!
Selon Fred ETHEVE <fred.etheve at wanadoo.fr>:
> Thank you, all,
> ECW/win was OK with trunk (1.9.90) until 2 days before new nightly...
> perhaps, since, gdal used has been 1.9???!!!
Yes, you should perhaps open a ticket (if not already done by someone else)
in OSGeo4W trac instance to ask for the gdal-ecw plugin to be regenerated
against GDAL 1.9
> It's time to have an opensource wavelets compression!!!
> 1) Somebody knows Epsilon CW? Is -it possible with GDAL1.9 linux and win?
Yes, but the Epsilon lib won't read ECWs and you have probably to build GDAL
yourself against it because few packages will build it.
> Sent: Thursday, March 22, 2012 8:56 PM
> To: 'qgis-developer'
> Subject: [Qgis-developer] RE: ECW!!!
> Hi all,
> Big, big problem in France with ECW!
> A lot of my students work with QGIS, and French IGN give rasters in
> ECW formats Exists a solution to use ECW? Compiling gdal???
> Regards,
> Fred
