[Qgis-developer] RE: ECW!!!
Frank Warmerdam
warmerdam at pobox.com
Fri Mar 23 13:38:42 EDT 2012
On Fri, Mar 23, 2012 at 6:03 AM, Fred ETHEVE <fred.etheve at wanadoo.fr> wrote:
> Thank you, all,
> ECW/win was OK with trunk (1.9.90) until 2 days before new nightly... perhaps, since, gdal used has been 1.9???!!!
Fred,
Ah, ok, this is why I asked. I would encourage you to file a ticket
against OSGeo4W. I will aim to upgrade the gdal-ecw package to work
with the new GDAL 1.9 package (gdal). With luck I could do this over
the weekend.
With all due respect, if you had explained the problem was
specifically with OSGeo4W to start I might have already had a plugin
built for you.
> It's time to have an opensource wavelets compression!!!
> 1) Somebody knows Epsilon CW? Is -it possible with GDAL1.9 linux and win?
> 2) How to grab one of the builds available at http://www.gisinternals.com/sdk/, have you a method?
If you find a GDAL 1.9 ECW plugin build from other sources you could drop it in:
C:/OSGeo4W/bin/gdalplugins/1.9/
This will only work safely if the plugin is built with the same version of MSVC
as GDAL 1.9 (Visual Studio 2008 in this case).
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
