[Qgis-developer] Geometry type does not match column type
Giuseppe Sucameli brush.tyler at gmail.com
Sat Mar 24 12:28:34 EDT 2012
Hi Salvatore,
On Sat, Mar 24, 2012 at 3:37 PM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> First issue:
> http://hub.qgis.org/issues/5109
the problem is that QGis tries to insert a POLYGON even if the column
has a MULTIPOLYGON geometry type.
Since in this moment QGis does not use ST_Multi in the query to
convert single to multi*, the only way is to edit the column
constraint.
> Second:
> If I use the SPIT plugin to import polygon features in PostGIS I
> get:
[CUT]
> ERROR:  Geometry type (Polygon) does not match column type
> (MultiPolygon)
It seems the same problem of the one above, but in SPIT you can
change the geometry type of new features by editing the value in the
"Feature class" column.
Regards.
Giuseppe Sucameli
