[Qgis-developer] import proprietary code inside a python plugin
G. Allegri giohappy at gmail.com
Mon Mar 26 08:23:32 EDT 2012
> I would advise you to change your software to adopt a loose coupling
> strategy
> between the qgis part and the esri part, either through web services, data
> exchange over a file or a database or something else not considered as a
> link
> in the GPL sense.
This is a solution that I have considered,  but it would require a lot of
overhead to do data structure exchange (python objects). I will consider
the way of cPickle or Google's protobuf.
giovanni
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120326/548ee7f2/attachment.html
