[Qgis-developer] GSoC 2012 Ideas
Сергей Бастраков bastrakov.sergei at gmail.com
Mon Mar 26 14:33:36 EDT 2012
hello again :)
i still think in which direction i should work. it may be exactly
SEXTANTE or it may be some qgis plugins, for example: HPGL, Orfeo
toolbox (which already working via processingframework) , some
algirithms from grass (ACCA, TOAR and etc). and apparently they will
run via the SEXTANTE (it have more votes than processingframework). it
is necessary to define a list of plugins that you would like to see in
qgis?
26 марта 2012 г. 17:23 пользователь Anne Ghisla <a.ghisla at gmail.com> написал:
> On Sun, 25 Mar 2012 21:22:30 +0200
> Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> 2012/3/25 Сергей Бастраков <bastrakov.sergei at gmail.com>:
>> > Hello!
>> > If I understand correctly, then SEXTANTE more likely to stay than
>> > the ProcessingFramework. But what about ideas for gsoc? I originally
>> > planned to work on the framework. in particular, add HPGL, my
>> > implementation of the ACCA algorithm and work on the framework
>> > itself.
>> ACCA and other RS tools would be a nice addition to QGIS!
> Sergei, all,
> I also support the integration with HPGL and ACCA.
> Are you willing to work on SEXTANTE Python version as well? If so,
> please coordinate with Arumozhi, so that you write two independent
> proposals. There is enough work to do for two students!
> I'd also ask Victor if he manages to mentor two students, maybe with
> the help of co-mentors.
> Best,
> Anne
> http://gis.cri.fmach.it/ghisla/
> Qgis-developer mailing list
