[Qgis-developer] import proprietary code inside a python plugin
    Vincent Picavet
    vincent.ml at oslandia.com
    Mon Mar 26 16:18:59 EDT 2012
> Ok, going through hyopthesis things are getting clear:
> my plugin is ok until it doesn't load something proprietary in its process
> space. As soon as it happens I must be able to provide the source of every
> code running in the same process. Right?
Right.
Importing esri python module falls into that category.
Vincent
> giovanni
> 2012/3/26 Vincent Picavet <vincent.ml at oslandia.com>
> > Hi,
> > Le lundi 26 mars 2012 21:32:31, G. Allegri a écrit :
> > > Ah, Tim, it's getting clear. Thanks.
> > > The key point is distribution, as always with GPL.
> > > In my case I won't distribute the ESRI geoprocessing libraries, they're
> > > part of the ArcGIS distribution, which is only availbale to users
> > > having
> > it
> > > installed on they're computers.
> > > The import satement will success only if the user have the ArcGIS
> > > product installed, otherwise it will fail. As a consequence I felt I
> > > could
> >  freely
> > > distribute my plugin as it doesn't strictly require the proprietary
> > > side
> > to
> > > run.
> > No you are wrong, as soon as your plugin is distributed and linked with
> > arcgis, you have to licence everything as GPL and therefore provide
> > sources.
> > > Doesn't GDAL do the same with ECW?! Ok GDAL are LGPL. Is this the key
> > > difference?
> > Yes
> > > Moreover it doesn't expose the QGis APIs to ArcGIS, and viceversa, so
> > > it only bridges the two world to interchange the data.
> > Bridging with an import is a link. If you want to exchange data, do it
> > without
> > the import and separate your modules.
> > please re-read my post and mentionned the FSF faq. Everything is in
> > there.
> > Vincent
> > > giovanni
> > > 2012/3/26 Tim Sutton <lists at linfiniti.com>
> > > > Hi
> > > > On Mon, Mar 26, 2012 at 4:52 PM, G. Allegri <giohappy at gmail.com>
> > wrote:
> > > > > Through the various considerations on this topic there are two
> > > > > positions
> > > > the
> > > > > seems contradictory to me:
> > > > > "I did some research on this, and the conclusion is that import is
> > > > > functionally and legally equivalent to linking during compilation,
> > > > > so everything that imports qgis must be GPL." [1]
> > > > So if you plan to distribute although technically possible to link to
> > > > a proprietary module, its not legall possible.
> > > > > then
> > > > > "you can import/link proprietary code into gpl code, provided you
> > have
> > > > > a license to do it."
> > > > So if you have the license to ESRI etc. to use their libraries you
> > > > are welcome to make yourself a QGIS frontend to ArcSomething, but
> > > > you cant legally distribute that.
> > > > > They probably mean different things and they're not in
> > > > > contradiction.
> > > > Being
> > > > > an important point to me, could you help in understanding it?
> > > > Above is my understanding of those points anyway....
> > > > Regards
> > > > Tim
> > > > > thanks a lot,
> > > > > Giovanni
> > > > > [1]
> > > > http://lists.osgeo.org/pipermail/qgis-developer/2012-March/018976.htm
> > > > l
> > > > > [2]
> > > > http://lists.osgeo.org/pipermail/qgis-developer/2012-March/019000.htm
> > > > l
> > > > > 2012/3/26 G. Allegri <giohappy at gmail.com>
> > > > >> I think you're right but watch the reality from a worldwide point
> > > > >> of
> > > > view.
> > > > >> I work mostly with foreign countries, not EU/USA. National offices
> > and
> > > > >> agencies budgets are far beyond the license fees, so they don't
> > > > >> care
> > > > for it
> > > > >> very much. They pay yearly for something that already do the work
> > they
> > > > need,
> > > > >> without having to do contracts for development, define
> > > > >> requirements,
> > > > etc.
> > > > >> This is the reality. In my courses, even those based on ESRI
> > software,
> > > > >> I always introduce FOSS solutions. Sometimes it raises interest,
> > most
> > > > >> of
> > > > times
> > > > >> they don't care. They want the job done, and they don't pay for
> > > > >> the
> > > > license.
> > > > >> That's it.
> > > > >> Anyway, if I wouldn't think that (most) of times a free solution
> > could
> > > > be
> > > > >> the best way, I wouldn't be here to talk about it ;)
> > > > >> giovanni
> > > > >> 2012/3/26 Sandro Santilli <strk at keybit.net>
> > > > >>> On Mon, Mar 26, 2012 at 03:31:53PM +0200, G. Allegri wrote:
> > > > >>> > I totally agree with you, but reality is a bit different. Many
> > > > >>> > agencies,
> > > > >>> > corporates, etc. are not considering to leave they're
> > > > >>> > infrastructure.
> > > > >>> It's their choice, they'll have to bear the consequences of that.
> > > > >>> > I suggest solutions to interoperate, not to switch the whole
> > thing.
> > > > >>> What I'm saying is that it just costs more. And rightly so.
> > > > >>> It is no interest of the free software users to make it any
> > cheaper,
> > > > >>> IMHO.
> > > > >>> > It would be easier, and a lot cheeper, if everybody talked one
> > > > >>> > language.
> > > > >>> +1
> > > > >>> > But we have hundreads of languages in the world, and we have to
> > > > >>> > deal with
> > > > >>> > this.
> > > > >>> People grow up learning the language of their mothers.
> > > > >>> Nobody has to pay a license to _use_ that language.
> > > > >>> And anyone can learn.
> > > > >>> We're really not talking about the same thing.
> > > > >>> --strk;
> > > > > _______________________________________________
> > > > > Qgis-developer mailing list
> > > > > Qgis-developer at lists.osgeo.org
> > > > > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > > > Tim Sutton - QGIS Project Steering Committee Member (Release
> > > > Manager) ==============================================
> > > > Please do not email me off-list with technical
> > > > support questions. Using the lists will gain
> > > > more exposure for your issues and the knowledge
> > > > surrounding your issue will be shared with all.
> > > > Visit http://linfiniti.com to find out about:
> > > >  * QGIS programming and support services
> > > >  * Mapserver and PostGIS based hosting plans
> > > >  * FOSS Consulting Services
> > > > Skype: timlinux
> > > > Irc: timlinux on #qgis at freenode.net
