[SoC] Re: [Qgis-developer] Proposal: QGIS Processing Framework improvements
Victor Olaya volayaf at gmail.com
Tue Mar 27 06:08:25 EDT 2012
Markus,
GRASS is integrated in SEXTANTE for QGIS just like it is in the Java
version of SEXTANTE (with some slight improvements that I am
doing...). However, I started the integration with SAGA and R before,
and those are now available from SEXTANTE, since more or less they
work fine, but GRASS is still unfinished and I have preferred to
deactivate it by now until it is finished, so you will not see it in
the list of available algorithms (I prefer not to confuse early
testers with things that are not yet working properly...). However, I
am currently working on that and you will have it soon ready
You opinion on this is more than welcome, as it was when I was
developing the GRASS-SEXTANTE connection for the Java version
And as Giovanni said, SEXTANTE is the framework, so you will have
GRASS tools also in other elements like the graphical modeler, the
batch processing interface, the Python console, etc
Regards
