[Qgis-user] Re: [Qgis-developer] Oracle Spatial Driver
G. Allegri giohappy at gmail.com
Fri Mar 30 07:33:14 EDT 2012
I agree Marco,
this was a proposal in case the license issue cannot be solved...
giovanni
2012/3/30 Marco Hugentobler <marco.hugentobler at sourcepole.ch>
>  Hi
> >This would provide a benefit also to the other sw using GDAL/OGR, and
> would solve the problem of the license (I suppose)
> Technically, I think it is better to write a native driver, because
> - the OGR model is not 100% identical with the QGIS one. E.g. one table
> can contain multiple geometry types, OGR has datasource/layer model, ...
> (probably more that I don't recall now). Providing a proper mapping between
> OGR model and QGIS model requires more effort than a native driver
> - more direct geometry transfer with native driver, thus better
> performance (with OGR driver, geometry is converted into OGR geometry first)
> Regards,
> Marco
> On 30.03.2012 11:49, G. Allegri wrote:
> What about moving the founding to improve the Oracle driver inside GDAL?
> The OCI driver would need some refactoring, as it was stated time ago by
> Frank.
>  giovanni
> 2012/3/30 haubourg <regis.haubourg at eau-adour-garonne.fr>
>> Hi All,
>> very interested in such a feature too!
>> If you do it, don't forget to offer an access to attribute tables (non SDO
>> ones) . many users just open a geographical table and a attribute table,
>> and
>> join them to map datas..
>> Régis
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Oracle-Spatial-Driver-tp4670299p4670680.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>>  _______________________________________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole -  Linux & Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120330/0686db62/attachment.html
