[Qgis-developer] Re: [Qgis-user] Re: [gdal-dev] Problems with gdal
and hdf files
Etienne Tourigny
etourigny.dev at gmail.com
Wed May 2 06:04:24 PDT 2012
On Wed, May 2, 2012 at 9:43 AM, Agustin Lobo <alobolistas at gmail.com> wrote:
> You are right. I was confusing bands and subdatasets.
> The following does not work:
> $ gdal_translate -b 4 lndsr.L5169054_05420101216.hdf test.tif
> Input file contains subdatasets. Please, select one of them for reading.
> The following works:
> $ gdal_translate -sds lndsr.L5169054_05420101216.hdf test.tif
> which results in test.tif1 to test.tif9 (probably should be test1.tif
> to test9.tif)
> but there is no way to actually select 1 or more specific subdatasets
same thing if you use the extended file syntax (e.g.
HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band1 ) .
You can probably work around this limitation by creating a vrt file
with gdalbuildvrt
> The most important
> QGIS complains:
> Cannot get GDAL raster band:
> R (raster) complains
>> r <- brick("lndsr.L5169054_05420101216.hdf")
> Error in .rasterObjectFromFile(x, objecttype = "RasterBrick", ...) :
> Cannot create a RasterLayer object from this file.
> In addition: Warning message:
> In .rasterFromGDAL(x, band = band, objecttype, ...) :
> GeoTransform values not available; georeferencing will not be correct
pass the vrt file you created to R, it should work as long as gdalinfo
works on that vrt file, although I have never tried it.
> but GDALinfo() is correct.
> Cannot test hdf5 or readGDAL() in R as the file is huge
> I guess the problem is in QGIS (and R package raster)? I'm not sure,
> as I do not know if
> subdatasets can be selected for reading using gdal.
Also see if you can load the vrt file in qgis!
> Agus
> 2012/5/2 Even Rouault <even.rouault at mines-paris.org>:
>> Selon Agustin Lobo <alobolistas at gmail.com>:
>>> Hi!
>>> The gdal info of a multiband satellite image in hdf is reported by
>>> gdal as "Size is 512, 512"
>>> in contradiction with the size of the subdatasets. QGIS and R
>>> (raster+rgdal) report an error at opening the file,
>>> while envi and HDFLook can open it with no problem. I include the
>>> gdalinfo output and the
>>> info reported by HDFLook. Any help appreciated.
>> I don't consider that to be a problem. The size reported on a GDAL dataset that
>> is only made of subdatasets (that is to say when the dataset has no raster bands
>> in itself, which is the case here) has no meaning, and is put to a default value
>> of 512x512. You have to open the subdatasets to know their size(in the case of
>> HDF4, the description of the subdataset also give them). There are cases where
>> the subdsatasets have different sizes, so it would be impossible to set a
>> significant value for the size of the dataset.
>>> Thanks
>>> Agus
>>> $ gdalinfo --version
>>> GDAL 1.8.0, released 2011/01/12
>>> $ gdalinfo lndsr.L5169054_05420101216.hdf
>>> Driver: HDF4/Hierarchical Data Format Release 4
>>> Files: lndsr.L5169054_05420101216.hdf
>>> Size is 512, 512
>>> Coordinate System is `'
>>> Metadata:
>>> DataProvider=UMD
>>> Satellite=LANDSAT_5
>>> Instrument=TM
>>> AcquisitionDate=2010-12-16T00:00:00.000000Z
>>> Level1ProductionDate=2012-02-22T00:00:00.000000Z
>>> SolarZenith=42.02009
>>> SolarAzimuth=141.4236
>>> WRS_System=2
>>> WRS_Path=169
>>> WRS_Row=54
>>> NumberOfBands=6
>>> BandNumbers=1, 2, 3, 4, 5, 7
>>> ShortName=L5TSR
>>> LocalGranuleID=L5TSR.a2010350.w2p169r054.020.2012117105207.hdf
>>> ProductionDate=2012-04-26T10:52:07Z
>>> PGEVersion=1.0.9
>>> ProcessVersion=1.0.4
>>> WestBoundingCoordinate=36.6199876177544
>>> EastBoundingCoordinate=38.780676500528
>>> NorthBoundingCoordinate=9.61826703329522
>>> SouthBoundingCoordinate=7.72285510894074
>>> OrientationAngle=0
>>> PixelSize=30
>>> HDFEOSVersion=HDFEOS_V2.4
>>> Cloud Mask Algo Version=CMReflectanceBasedv1.0
>>> Subdatasets:
>> SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band1
>>> SUBDATASET_1_DESC=[6961x7901] band1 Grid (16-bit integer)
>> SUBDATASET_2_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band2
>>> SUBDATASET_2_DESC=[6961x7901] band2 Grid (16-bit integer)
>> SUBDATASET_3_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band3
>>> SUBDATASET_3_DESC=[6961x7901] band3 Grid (16-bit integer)
>> SUBDATASET_4_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band4
>>> SUBDATASET_4_DESC=[6961x7901] band4 Grid (16-bit integer)
>> SUBDATASET_5_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band5
>>> SUBDATASET_5_DESC=[6961x7901] band5 Grid (16-bit integer)
>> SUBDATASET_6_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band7
>>> SUBDATASET_6_DESC=[6961x7901] band7 Grid (16-bit integer)
>> SUBDATASET_7_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:atmos_opacity
>>> SUBDATASET_7_DESC=[6961x7901] atmos_opacity Grid (16-bit integer)
>> SUBDATASET_8_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:lndsr_QA
>>> SUBDATASET_8_DESC=[6961x7901] lndsr_QA Grid (16-bit integer)
>> SUBDATASET_9_NAME=HDF4_EOS:EOS_GRID:"lndsr.L5169054_05420101216.hdf":Grid:band6
>>> SUBDATASET_9_DESC=[6961x7901] band6 Grid (16-bit integer)
>>> Corner Coordinates:
>>> Upper Left ( 0.0, 0.0)
>>> Lower Left ( 0.0, 512.0)
>>> Upper Right ( 512.0, 0.0)
>>> Lower Right ( 512.0, 512.0)
>>> Center ( 256.0, 256.0)
>>> HDFLooK:
>>> Global attributes: 26
>>> DataProvider:
>> UMDLANDSAT_5TM2010-12-16T00:00:00.000000Z2012-02-22T00:00:00.000000Z SolarZenith: 42.0201
>>> SolarAzimuth: 141.424
>>> 2 WRS_Path: 169
>>> WRS_Row: 54
>>> NumberOfBands: 6
>>> BandNumbers: 1, 2, 3, 4, 5, 7
>> L5TSRL5TSR.a2010350.w2p169r054.020.2012117105207.hdf2012-04-26T10:52:07Z1.0.91.0.4 WestBoundingCoordinate: 36.62
>>> EastBoundingCoordinate: 38.7807
>>> NorthBoundingCoordinate: 9.61827
>>> SouthBoundingCoordinate: 7.72286
>>> OrientationAngle: 0
>>> PixelSize: 30
>> HDFEOS_V2.4-----------------------------------------------------------------------------------
>>> GROUP=SwathStructure
>>> END_GROUP=SwathStructure
>>> GROUP=GridStructure
>>> GROUP=GRID_1
>>> GridName="Grid"
>>> XDim=7901
>>> YDim=6961
>>> UpperLeftPointMtrs=(238785.000000,1063215.000000)
>>> LowerRightMtrs=(475815.000000,854385.000000)
>>> Projection=GCTP_UTM
>>> ZoneCode=37
>>> SphereCode=12
>>> GridOrigin=HDFE_GD_UL
>>> GROUP=Dimension
>>> END_GROUP=Dimension
>>> GROUP=DataField
>>> OBJECT=DataField_0
>>> DataFieldName="band1"
>>> DataType=DFNT_INT16
>>> DimList=("YDim","XDim")
>>> END_OBJECT=DataField_0
>>> OBJECT=DataField_1
>>> DataFieldName="band2"
>>> DataType=DFNT_INT16
>>> END_OBJECT=DataField_1
>>> OBJECT=DataField_2
>>> DataFieldName="band3"
>>> DataType=DFNT_INT16
>>> END_OBJECT=DataField_2
>>> OBJECT=DataField_3
>>> DataFieldName="band4"
>>> DataType=DFNT_INT16
>>> END_OBJECT=DataField_3
>>> OBJECT=DataField_4
>>> DataFieldName="band5"
>>> DataType=DFNT_INT16
>>> END_OBJECT=DataField_4
>>> OBJECT=DataField_5
>>> DataFieldName="band7"
>>> DataType=DFNT_INT16
>>> END_OBJECT=DataField_5
>>> OBJECT=DataField_6
>>> DataFieldName="atmos_opacity"
>>> DataType=DFNT_INT16
>>> END_OBJECT=DataField_6
>>> OBJECT=DataField_7
>>> DataFieldName="lndsr_QA"
>>> DataType=DFNT_INT16
>>> END_OBJECT=DataField_7
>>> OBJECT=DataField_9
>>> DataFieldName="band6"
>>> DataType=DFNT_INT16
>>> END_OBJECT=DataField_9
>>> END_GROUP=DataField
>>> GROUP=MergedFields
>>> END_GROUP=MergedFields
>>> END_GROUP=GRID_1
>>> END_GROUP=GridStructure
>>> GROUP=PointStructure
>>> END_GROUP=PointStructure
>>> END
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Qgis-user mailing list
