[Qgis-developer] Bye bye SPIT?
Tim Sutton
lists at linfiniti.com
Wed May 2 14:00:20 PDT 2012
Hi Folks
I guess we can revisit this for 2.0 and I will leave both spit and
dbmanager in place for now.
Regards
Tim
On Wed, May 2, 2012 at 10:22 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> -1 from me. IMO leave it for 2.0 release. Maybe add a message into the
> SPIT dialog that says "I will be removed in the next release by learn to use
> X to upload into PostGIS"
> I have never had issues with uploading layers into postgis using SPIT
> however on the other had dbmanger still feels very touch and go with if it
> will work or not.
> - Nathan
> On Thu, May 3, 2012 at 4:59 AM, Werner Macho <werner.macho at gmail.com> wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> On 05/02/2012 07:31 PM, Horst Düster wrote:
>> > +1 on Mayeuls comment
>> > mayeul.kauffmann at free.fr schrieb:
>> >>> oh, yes, you're right - it's PostGIS Manager that requires
>> >>> shp2pgsql,
>> >> not SPIT. My mistake. Sure, duplication of tools is bad. But
>> >> removing SPIT would mean removing the *only* (correct?) QGIS GUI
>> >> tool to load shapefiles into postgis without external
>> >> dependencies. Do we want to get read of this before putting it in
>> >> DB manager?
>> The same with me (beside the fact that I just learned howto use SPIT
>> (thanks Horst)) it seems much more clearer to me using SPIT than using
>> the dbmanager (for now) ..
>> Don't get me wrong .. dbmanager is great but as long as SPIT is more
>> intuitive (maybe because it just does ONE thing) I'd like to wait with
>> removing it until a filedialog import has been implemented that
>> creates something like the batch upload which you currently see when
>> you add more than one shapefile ..
>> But I am quite sure guiseppe will have that soon :)
>> So..
>> - -1 from me for removing it right now (and probably think about the
>> dependencies too which mayeul pointed out)
>> Beside that ..
>> What about creating hints for obsolete plugins that are getting
>> removed with a hint that the function has been
>> integrated/extended/moved to "the new plugin" .. or maybe a hint
>> inside the plugin that this will become obsolete soon because the
>> function will be available in core/new-plugin-name.
>> marking plugins like that for at least one "official"-release-period
>> will probably easen the migration for the user too..
>> kind regards
>> Werner
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.12 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAk+hhAcACgkQDAH1YiCxBgkkdwCeOiDF96J6FTJdbQe+8IVb1ESG
>> NwIAnj3euWQOLrYBjion8y0ifngCGLWL
>> =E8B0
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
