[Qgis-developer] Re: build qgis in Windows - missing GEOS and
	PROJ.4
    Tim Sutton
    lists at linfiniti.com
    Sat May  5 09:32:45 PDT 2012
Hi
Are you sure you are launching cmake from in an osgeo4w shell? If you
do that everything should *just work*. Also you should be able to set
a LIB_DIR env var and the cmake find rules will look there for libs.
So normally you should not need to tweak much in cmake other than
fixing the paths for gnu utils.
Regards
Tim
On Sat, May 5, 2012 at 3:23 AM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> It seems I had overlooked the osgeo4w /include and /lib directories,
> which contain all the necessary libs.
> However, how can things be setup so that cmake looks for all
> dependencies in the osgeo4w directory, instead of specifying each one
> manually?
> regards,
> Etienne
> On Fri, May 4, 2012 at 3:46 PM, Etienne Tourigny
>> Hi all,
>> following the Windows building instructions at [1] using VS2008
>> Express, cmake complains that I am missing GEOS and PROJ.
>> I get
>> GEOS_INCLUDE_DIR-NOTFOUND
>> GEOS_LIBRARY-NOTFOUND
>> PROJ_INCLUDE_DIR-NOTFOUND
>> PROJ_LIBRARY-NOTFOUND
>> The instructions do not say anything about building GEOS and PROJ.4
>> with Visual Studio (but there are instruction for building GEOS with
>> MINGW)...
>> [1] http://hub.qgis.org/projects/quantum-gis/repository/revisions/master/entry/INSTALL
>> thanks
>> Etienne
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
