[Qgis-developer] Re: build qgis in Windows - missing GEOS and
PROJ.4
Etienne Tourigny
etourigny.dev at gmail.com
Mon May 7 07:24:36 PDT 2012
I tried again and here is the log. basically missing
PROJ_LIBRARY
SPATIALINDEX_INCLUDE_DIR
SPATIALINDEX_LIBRARY
SPATIALITE_LIBRARY
SQLITE3_LIBRARY
although they are in the correct path (c:/osgeo4w/lib)
I do have C:/OSGeo4W/lib/sqlite3_i.lib but it is not detected,
although the include is.
Where did you get spatialindex_i.lib from ? I did not find it in
osgeo4w installer and I had to download it from
http://download.osgeo.org/libspatialindex/libspatialindex-1.6.1-win32.zip
After copying them to osgeo4w dirs, it was found by cmake.
It would be great to have it added to osgeo4w!
Thanks
Etienne
Check for working C compiler using: Visual Studio 9 2008
Check for working C compiler using: Visual Studio 9 2008 -- works
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Check for working CXX compiler using: Visual Studio 9 2008
Check for working CXX compiler using: Visual Studio 9 2008 -- works
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Quantum GIS version: 1.8.0 Lisboa (10800)
Could not find GRASS
Touch support disabled
Found GEOS: C:/OSGeo4W/lib/geos_c_i.lib
Found GDAL: C:/OSGeo4W/lib/gdal_i.lib
Found Expat: C:/OSGeo4W/lib/libexpat.lib
Found Qwt: C:/OSGeo4W/lib/qwt5.lib (5.2.1)
CMake Error at CMakeLists.txt:180 (MESSAGE):
sqlite3 dependency was not found (try compiling with internal spatialite)!
Found PostgreSQL: C:/OSGeo4W/lib/libpq.lib
CMake Error at CMakeLists.txt:194 (MESSAGE):
Some dependencies were not found!
Looking for Q_WS_X11
Looking for Q_WS_X11 - not found.
Looking for Q_WS_WIN
Looking for Q_WS_WIN - found
Looking for Q_WS_QWS
Looking for Q_WS_QWS - not found.
Looking for Q_WS_MAC
Looking for Q_WS_MAC - not found.
Found Qt4: C:/OSGeo4W/bin/qmake.exe (found suitable version "4.7.1",
required is "4.4.0")
Found ZLIB: C:/OSGeo4W/lib/zlib.lib (found version "1.2.3")
Found zlib: C:/OSGeo4W/lib/zlib.lib
Pedantic compiler settings enabled
Found PythonInterp: C:/OSGeo4W/bin/python.exe (found version "2.7.2")
Found Python executable: C:/OSGeo4W/bin/python.exe
Found Python version: 2.7.2
Found Python library: C:/OSGeo4W/apps/python27/libs/python27.lib
Found SIP version: 4.13.1
Found PyQt4 version: 4.8.3
Found GSL: C:/OSGeo4W/lib/gsl.lib;C:/OSGeo4W/lib/cblas.lib
txt2tags not found - disabled
Ctest Binary Directory set to: C:/OSGeo4W/build/build5/output/bin
CMake Error: The following variables are used in this project, but
they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the
CMake files:
PROJ_LIBRARY
linked by target "qgis_core" in directory
C:/OSGeo4W/build/Quantum-GIS/src/core
linked by target "crssync" in directory
C:/OSGeo4W/build/Quantum-GIS/src/crssync
linked by target "qgis_applicationtest" in directory
C:/OSGeo4W/build/Quantum-GIS/tests/src/core
linked by target "qgis_contrastenhancementtest" in directory
linked by target "qgis_coordinatereferencesystemtest" in directory
linked by target "qgis_expressiontest" in directory
linked by target "qgis_filewritertest" in directory
linked by target "qgis_geometrytest" in directory
linked by target "qgis_maplayertest" in directory
linked by target "qgis_maprenderertest" in directory
linked by target "qgis_pointtest" in directory
linked by target "qgis_rasterlayertest" in directory
linked by target "qgis_regression1141" in directory
linked by target "qgis_regression992" in directory
linked by target "qgis_rendererstest" in directory
linked by target "qgis_rulebasedrenderertest" in directory
linked by target "qgis_searchstringtest" in directory
linked by target "qgis_vectorlayertest" in directory
linked by target "qgis_ziplayertest" in directory
linked by target "qgis_zoomtest" in directory
C:/OSGeo4W/build/Quantum-GIS/tests/src/gui
used as include directory in directory C:/OSGeo4W/build/Quantum-GIS/src/core
SPATIALITE_LIBRARY
linked by target "offlineeditingplugin" in directory
C:/OSGeo4W/build/Quantum-GIS/src/plugins/offline_editing
SQLITE3_LIBRARY
linked by target "qgis_help" in directory
C:/OSGeo4W/build/Quantum-GIS/src/helpviewer
linked by target "qbrowser" in directory
C:/OSGeo4W/build/Quantum-GIS/src/browser
linked by target "qgis_bench" in directory
C:/OSGeo4W/build/Quantum-GIS/tests/bench
Configuring incomplete, errors occurred!
On Mon, May 7, 2012 at 4:07 AM, G. Allegri <giohappy at gmail.com> wrote:
> PROJ_LIBRARY: C:/OSGeo4W/lib/proj_i.lib
> SPATIALINDEX_LIBRARY: C:/OSGeo4W/lib/spatialindex_i.lib
> I didn't need to set sqlite3, because it finds it correctly
> as C:/OSGeo4W/lib/sqlite3_i.lib
> giovanni
> 2012/5/5 Etienne Tourigny <etourigny.dev at gmail.com>
>> Yes I did install them beforehand, the point is that they were not
>> detected automatically.
>> The spatialindex stuff is rather new (I thinks\), so there might need
>> to be some improvements in the cmake files for Windows.
>> Same for others which have been around for some time
>> (proj,spatialite,sqlite)
>> Etienne
>> On Sat, May 5, 2012 at 2:24 PM, G. Allegri <giohappy at gmail.com> wrote:
>> > You also need to install those dev libs from osgeo4w. I had to set the
>> > proj
>> > lib path manually.
>> > I'm out of home, as soon as I'll be back to my pc I can share my notes.
>> > In the meanwhile I can only confirm that the build procedure for MSVC
>> > works
>> > fine for all the qgis components (also python bindings).
>> > giovanni
>> > Inviato da dispositivo mobile
>> > Il giorno 05/mag/2012 19.06, "Etienne Tourigny"
>> > <etourigny.dev at gmail.com> ha
>> > scritto:
>> >> Hi,
>> >> I got it working last night when running form the osgeo4w shell (my
>> >> mistake), but there were still a number of missing entries which I had
>> >> to add (which are also installed by osgeo4w)
>> >> PROJ_LIBRARY-NOTFOUND
>> >> SPATIALINDEX_INCLUDE_DIR-NOTFOUND
>> >> SPATIALINDEX_LIBRARY-NOTFOUND
>> >> SPATIALITE_LIBRARY-NOTFOUND
>> >> SQLITE3_LIBRARY-NOTFOUND
>> >> I tried adding LIB_DIR to both the osgeo script and as a CMake entry,
>> >> to no avail.
>> >> Thanks
>> >> Etienne
>> >> thanks
>> >> Etienne
>> >> On Sat, May 5, 2012 at 1:32 PM, Tim Sutton <lists at linfiniti.com> wrote:
>> >> > Hi
>> >> > Are you sure you are launching cmake from in an osgeo4w shell? If you
>> >> > do that everything should *just work*. Also you should be able to set
>> >> > a LIB_DIR env var and the cmake find rules will look there for libs.
>> >> > So normally you should not need to tweak much in cmake other than
>> >> > fixing the paths for gnu utils.
>> >> > Regards
>> >> > Tim
>> >> > On Sat, May 5, 2012 at 3:23 AM, Etienne Tourigny
>> >> > <etourigny.dev at gmail.com> wrote:
>> >> >> It seems I had overlooked the osgeo4w /include and /lib directories,
>> >> >> which contain all the necessary libs.
>> >> >> However, how can things be setup so that cmake looks for all
>> >> >> dependencies in the osgeo4w directory, instead of specifying each
>> >> >> one
>> >> >> manually?
>> >> >> regards,
>> >> >> Etienne
>> >> >> On Fri, May 4, 2012 at 3:46 PM, Etienne Tourigny
>> >> >>> Hi all,
>> >> >>> following the Windows building instructions at [1] using VS2008
>> >> >>> Express, cmake complains that I am missing GEOS and PROJ.
>> >> >>> I get
>> >> >>> GEOS_INCLUDE_DIR-NOTFOUND
>> >> >>> GEOS_LIBRARY-NOTFOUND
>> >> >>> PROJ_INCLUDE_DIR-NOTFOUND
>> >> >>> The instructions do not say anything about building GEOS and PROJ.4
>> >> >>> with Visual Studio (but there are instruction for building GEOS
>> >> >>> with
>> >> >>> MINGW)...
>> >> >>> [1]
>> >> >>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/master/entry/INSTALL
>> >> >>> thanks
>> >> >>> Etienne
>> >> >> _______________________________________________
>> >> >> Qgis-developer mailing list
>> >> >> Qgis-developer at lists.osgeo.org
>> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> > Tim Sutton - QGIS Project Steering Committee Member (Release
>> >> > Manager)
>> >> > Please do not email me off-list with technical
>> >> > support questions. Using the lists will gain
>> >> > more exposure for your issues and the knowledge
>> >> > surrounding your issue will be shared with all.
>> >> > Visit http://linfiniti.com to find out about:
>> >> > * QGIS programming and support services
>> >> > * Mapserver and PostGIS based hosting plans
>> >> > * FOSS Consulting Services
>> >> > Skype: timlinux
>> >> > Irc: timlinux on #qgis at freenode.net
