[Qgis-developer] Re: build qgis in Windows - missing GEOS and
PROJ.4
G. Allegri
giohappy at gmail.com
Mon May 7 00:07:03 PDT 2012
PROJ_LIBRARY: C:/OSGeo4W/lib/proj_i.lib
SPATIALINDEX_LIBRARY: C:/OSGeo4W/lib/spatialindex_i.lib
I didn't need to set sqlite3, because it finds it correctly
as C:/OSGeo4W/lib/sqlite3_i.lib
giovanni
2012/5/5 Etienne Tourigny <etourigny.dev at gmail.com>
> Yes I did install them beforehand, the point is that they were not
> detected automatically.
> The spatialindex stuff is rather new (I thinks\), so there might need
> to be some improvements in the cmake files for Windows.
> Same for others which have been around for some time
> (proj,spatialite,sqlite)
> Etienne
> On Sat, May 5, 2012 at 2:24 PM, G. Allegri <giohappy at gmail.com> wrote:
> > You also need to install those dev libs from osgeo4w. I had to set the
> proj
> > lib path manually.
> > I'm out of home, as soon as I'll be back to my pc I can share my notes.
> > In the meanwhile I can only confirm that the build procedure for MSVC
> works
> > fine for all the qgis components (also python bindings).
> > giovanni
> > Inviato da dispositivo mobile
> > Il giorno 05/mag/2012 19.06, "Etienne Tourigny" <etourigny.dev at gmail.com>
> ha
> > scritto:
> >> Hi,
> >> I got it working last night when running form the osgeo4w shell (my
> >> mistake), but there were still a number of missing entries which I had
> >> to add (which are also installed by osgeo4w)
> >> PROJ_LIBRARY-NOTFOUND
> >> SPATIALINDEX_INCLUDE_DIR-NOTFOUND
> >> SPATIALINDEX_LIBRARY-NOTFOUND
> >> SPATIALITE_LIBRARY-NOTFOUND
> >> SQLITE3_LIBRARY-NOTFOUND
> >> I tried adding LIB_DIR to both the osgeo script and as a CMake entry,
> >> to no avail.
> >> Thanks
> >> Etienne
> >> thanks
> >> Etienne
> >> On Sat, May 5, 2012 at 1:32 PM, Tim Sutton <lists at linfiniti.com> wrote:
> >> > Hi
> >> > Are you sure you are launching cmake from in an osgeo4w shell? If you
> >> > do that everything should *just work*. Also you should be able to set
> >> > a LIB_DIR env var and the cmake find rules will look there for libs.
> >> > So normally you should not need to tweak much in cmake other than
> >> > fixing the paths for gnu utils.
> >> > Regards
> >> > Tim
> >> > On Sat, May 5, 2012 at 3:23 AM, Etienne Tourigny
> >> > <etourigny.dev at gmail.com> wrote:
> >> >> It seems I had overlooked the osgeo4w /include and /lib directories,
> >> >> which contain all the necessary libs.
> >> >> However, how can things be setup so that cmake looks for all
> >> >> dependencies in the osgeo4w directory, instead of specifying each one
> >> >> manually?
> >> >> regards,
> >> >> Etienne
> >> >> On Fri, May 4, 2012 at 3:46 PM, Etienne Tourigny
> >> >>> Hi all,
> >> >>> following the Windows building instructions at [1] using VS2008
> >> >>> Express, cmake complains that I am missing GEOS and PROJ.
> >> >>> I get
> >> >>> GEOS_INCLUDE_DIR-NOTFOUND
> >> >>> GEOS_LIBRARY-NOTFOUND
> >> >>> PROJ_INCLUDE_DIR-NOTFOUND
> >> >>> The instructions do not say anything about building GEOS and PROJ.4
> >> >>> with Visual Studio (but there are instruction for building GEOS with
> >> >>> MINGW)...
> >> >>> [1]
> http://hub.qgis.org/projects/quantum-gis/repository/revisions/master/entry/INSTALL
> >> >>> thanks
> >> >>> Etienne
> >> >> _______________________________________________
> >> >> Qgis-developer mailing list
> >> >> Qgis-developer at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> > Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> >> > Please do not email me off-list with technical
> >> > support questions. Using the lists will gain
> >> > more exposure for your issues and the knowledge
> >> > surrounding your issue will be shared with all.
> >> > Visit http://linfiniti.com to find out about:
> >> > * QGIS programming and support services
> >> > * Mapserver and PostGIS based hosting plans
> >> > * FOSS Consulting Services
> >> > Skype: timlinux
> >> > Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120507/14e7d310/attachment-0001.html
